Old 10-16-2016, 18:18   #31 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
Share files are without phone model name
How to choose right one
Old 10-21-2016, 17:31   #32 (permalink)
Member: 2601431
Thanks Meter: 35
I need the md5 fix for a G531H please.
The Following User Says Thank You to henrucci For This Useful Post:
Old 10-23-2016, 21:04   #33 (permalink)
Member: 2145583
Thanks Meter: 7
j320m please solution frp
Old 10-23-2016, 21:09   #34 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
put phone in donwadlo mode, select g925f, and do reset frp/eep.....
Old 10-24-2016, 03:03   #35 (permalink)
Member: 2145583
Thanks Meter: 7
Old 10-25-2016, 01:03   #36 (permalink)
Member: 92260
Thanks Meter: 843
Originally Posted by blang View Post
For fix this issue need flash MD5 file, where 1 byte set to 0 (dissable MD5 check).
U can use this files or edit own corrected md5 files
Which byte(s) in the combi file can we edit to fix the error.
Offset 0x from the beginning of the file?
Thanks.
Old 11-03-2016, 22:18   #37 (permalink)
Member: 2644211
G531h Multocore checksum errorel
G531h multicore check message continue after z3box frp combination file use. pls help me
Old 11-04-2016, 07:23   #38 (permalink)
Member: 92260
Thanks Meter: 843
Multi-Core error solved!!
Thanks.
Since noone explained in details so far, here it is...
btw. Thanks Blang!
Use a hex editor and do the following:
in file md5.tar (for example md5_FAC_FACFA51_J320FXXU0APA4_CL6921306_QB8383786_ REV00_user_mid_noship.tar)
at hex offset 0x0200 change 0x01 to 0x00
or in file md5.img (un-tar-ed image)
at hex offset 0x0000 change 0x01 to 0x00
then re-tar the file
Works on all combi md5.tar files, and it's just friggin' magical!!
Old 11-06-2016, 01:31   #39 (permalink)
Member: 2601431
Thanks Meter: 35
Octoplus Box fix this now since 3 weeks ago with the new update.
Old 11-16-2016, 12:25   #40 (permalink)
Crazy Poster
Member: 141715
Thanks Meter: 3
it's ok,
z3x is the best tool
thannnnnnnnnnnnnnnnnnks
Old 11-23-2016, 16:31   #41 (permalink)
Member: 181405
Thanks Meter: 249
I need repair SM-G930F MULTICORE CHECKSUM MODE
Old 12-11-2016, 21:07   #42 (permalink)
Member: 1242594
thankz sir.....pinagpawisan ako ng malapot kala ko magbabayad na ko sa may ari, buti may solution.
Old 12-12-2016, 10:55   #43 (permalink)
Member: 311858
Thanks Meter: 17
i need solution MULTICORE CHECKSUM MODE SM-J110G
thanks
The Following User Says Thank You to wency For This Useful Post:
Old 12-16-2016, 12:10   #44 (permalink)
Member: 2660664
Originally Posted by bulutiletisim View Post
j320h multicore checksum mode % % ok thank you blang
how to do j320h multicore checksum mode
please
Old 12-17-2016, 06:00   #45 (permalink)
yandbass's Avatar
Member: 101268
Thanks Meter: 120
multicore checksum
use the attached file posted by bavesore. it works on most of the models.
File Type: rar CHECKSUM MODE OFF BY bavesore.rar (355 Bytes, 1745 views)
The Following 18 Users Say Thank You to yandbass For This Useful Post:
Page generated in 0.19122 seconds with 9 queries
