03-29-2016, 16:55 | #1 (permalink) |
Crazy Poster Join Date: Jul 2014 Location: Michigan
Member: 2223658 Status: Offline Thanks Meter: 21 | Sprint domestic unlocking explained for all samsung devices supported by z3x box I am not going to explain how to unlock each device so dont waste your time asking. But I am going to tell you all the procedure to sprint domestic unlock all samsung devices supported by z3x most devices: all you have to do is turn adb on and connect to the box and click domestic unlock. after you must go into settings of the phone mobile networks preferred network time GSM ( automatic works, but not better than GSM) if no network after, after you must go into service mode and turn on gcf mode which is explained in many threads (*#0011#) IF YOU CANNOT GET INTO GCF MODE (*must have root*) 1. ROOT THE PHONE WHICHEVER WAY YOU WANT TO HAVE ROOT ACCESS 2. DOWNLOAD APP CALLED "PHONE INFO" FOUND HERE OR PLAY STORE Phone INFO ?Samsung? 3.4.3 APK 3. CLICK MENU BAR IN TOP LEFT CORNER 4. CLICK OTHER TOOLS 5. CLICK SERVICE MODE (ROOT) MUST HAVE ROOT FOR THIS TO WORK AND FROM THERE YOU CAN ACCESS GCF IF YOU TURN GCF ON AND STILL NO NETWORK OR NO ROOT APPLICABLE NOTE 4- I DOWNGRADE TO 4.4.4 AND IT WORKS RIGHT AWAY GALAXY S5- FLASH A DIFFERENT MODEM FOR BYPASS MSL NOTE 3- FLASH A DIFFERENT MODEM THESE ARE THE ONLY 3 DEVICES THAT I HAVE EVER HAD ISSUES WITH. ALL IVE DONE HAVE BEEN ONES THAT WERE BAD ESN SO THIS WORKS GREAT!!! 4G PROBLEM I have not been able to show 4g instead of 3g. but one thing I know is when sprint devices are put into roaming mode, it shows 3g. When these phones get unlocked they are basically put into roaming mode, and by checking the data speeds especially with t-mobile the phone is very fast, much faster than 3g speeds! SO WHO CARES WHAT IT SAYS AT THE TOP LET THE CUSTOMER KNOW IF THEIR PLAN CONSISTS OF 4G DATA, YOU WILL GET IT! SPRINT DEVICES ON METROPCS I have had no luck at all using these sprint devices on metropcs as you must pair the sim with the imei and they constantly reject sprint imei's which is bs but hey, if anybody figures it out let me know!!! if anybody needs anything else explained just inbox me and I will be glad to help. Soon I will be placing step by step tutorials on youtube so be ready!!! |
The Following 11 Users Say Thank You to joey habbo For This Useful Post: |
03-29-2016, 23:18 | #2 (permalink) | |
Junior Member Join Date: Dec 2008
Member: 914319 Status: Offline Thanks Meter: 1 | Quote:
04-07-2016, 15:51 | #3 (permalink) |
Junior Member Join Date: Nov 2014 Location: USA
Member: 2294832 Status: Offline Thanks Meter: 1 | i unlocked my friends note 5 sprint and didnt root it. just make sure usb debug is on. he is using it for metro. we called metro to add imei phone to their database. its working fine but only on 3g, still its fast. |
The Following User Says Thank You to boneman990 For This Useful Post: |
04-16-2016, 14:56 | #5 (permalink) |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | You will not be able to get 4G / LTE in the USA on GSM carriers. G900P, N900P, N910P etc do not support 4g / LTE GSM bands. You will only be able to get 3G speed in USA with these sprint devices after you unlock them for domestic use. |
04-19-2016, 07:02 | #9 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | S6 edge sm-g925p sprint 6.0.1 not work unlock Operation: Unlock SPRNT Selected model: SM-G925P Software version: 25.1 Waiting ADB device... OK Reading phone info... Model: SM-G925P Android version: 6.0.1 Product code: Not Active Phone version: G925PVPU3CPB6 PDA version: G925PVPU3CPB6 CSC version: G925PSPT3CPB6 CSC country code: USA CSC sales code: SPR HW version: G925P.02 Phone S/N: 00000000000 Modem board: MDM9635M RF cal date: 2015.08.03 IMEI: Initialization AT RIL... error Done with Samsung Tool PRO v.25.1 |
The Following User Says Thank You to creconinfo For This Useful Post: |
04-21-2016, 20:29 | #11 (permalink) |
Freak Poster Join Date: Nov 2006 Location: NJ, USA
Member: 399404 Status: Offline Thanks Meter: 70 | I have a g900p on 6.0.1 and need to unlock but I get ; UNLOCK INSTRUCTIONS: Direct Unlock: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button. Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 5. Select device in ADB settings. 6. Press 'Unlock Domestic' button. Operation: Unlock SPRNT Selected model: SM-G900P Selected port: COM3 SAMSUNG Mobile USB Serial Port Software version: 25.1 Waiting ADB device... OK Reading phone info... Model: SM-G900P Android version: 6.0.1 Product code: Not Active Phone version: G900PVPU3CPCA PDA version: G900PVPU3CPCA CSC version: G900PSPT3CPCA CSC country code: USA CSC sales code: SPR HW version: G900P.04 Phone S/N: 00000000000 Modem board: MSM8974PRO RF cal date: 2014.05.21 IMEI: Initialization AT RIL... error Done with Samsung Tool PRO v.25.1 |
04-24-2016, 16:29 | #12 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | SM-G900P SPRNT Unlocking... OK SM-G900P SPRNT Unlocking...Done! Before flshing: Code: [ 4/24/2016 11:29:00 AM ] Operation: Unlock SPRNT [ 4/24/2016 11:29:00 AM ] Selected model: SM-G900P [ 4/24/2016 11:29:00 AM ] Selected port: COM19 RIM Virtual Serial Port v2 [ 4/24/2016 11:29:00 AM ] Software version: 25.2 [ 4/24/2016 11:29:00 AM ] [ 4/24/2016 11:29:00 AM ] Waiting ADB device... [ 4/24/2016 11:29:00 AM ] Please, allow USB debugging on phone... OK [ 4/24/2016 11:29:00 AM ] Reading phone info... [ 4/24/2016 11:29:00 AM ] Model: SM-G900P [ 4/24/2016 11:29:00 AM ] Android version: 5.0 [ 4/24/2016 11:29:00 AM ] Product code: Not Active [ 4/24/2016 11:29:00 AM ] Phone version: G900PVPU3BOG1 [ 4/24/2016 11:29:00 AM ] PDA version: G900PVPU3BOG1 [ 4/24/2016 11:29:00 AM ] CSC version: G900PSPT1BOA6 [ 4/24/2016 11:29:00 AM ] CSC country code: USA [ 4/24/2016 11:29:00 AM ] CSC sales code: XAS [ 4/24/2016 11:29:00 AM ] HW version: G900P.04 [ 4/24/2016 11:29:00 AM ] Phone S/N: 00000000000 [ 4/24/2016 11:29:00 AM ] Modem board: MSM8974PRO [ 4/24/2016 11:29:00 AM ] RF cal date: 2014.04.26 [ 4/24/2016 11:29:00 AM ] IMEI: [ 4/24/2016 11:29:00 AM ] Initialization AT RIL... error After flashing G900PVPU3BOG1_G900PSPT3BOG1_G900PVPU3BOG1_HOME.tar Code: UNLOCK INSTRUCTIONS: Direct Unlock: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button. Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 5. Select device in ADB settings. 6. Press 'Unlock Domestic' button. Operation: Unlock SPRNT Selected model: SM-G900P Selected port: COM24 Z3X BOX Serial Port Software version: 25.2 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G900P Android version: 5.0 Product code: Not Active Phone version: G900PVPU3BOG1 PDA version: G900PVPU3BOG1 CSC version: G900PSPT3BOG1 CSC country code: USA CSC sales code: XAS HW version: G900P.04 Phone S/N: 00000000000 Modem board: MSM8974PRO RF cal date: 2014.04.26 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.2 Only 3G working 4G Not working |
