Old 07-11-2016, 01:36   #16 (permalink)
Member: 2428732
Thanks Meter: 22
Originally Posted by joey habbo View Post
I am an avid unlocker and user of z3x box and I truly love it.
I am not going to explain how to unlock each device so dont waste your time asking. But I am going to tell you all the procedure to sprint domestic unlock all samsung devices supported by z3x
most devices:
all you have to do is turn adb on and connect to the box and click domestic unlock.
after you must go into settings of the phone
mobile networks
preferred network time
GSM ( automatic works, but not better than GSM)
if no network after,
after you must go into service mode and turn on gcf mode
which is explained in many threads (*#0011#)
IF YOU CANNOT GET INTO GCF MODE (*must have root*)
1. ROOT THE PHONE WHICHEVER WAY YOU WANT TO HAVE ROOT ACCESS
2. DOWNLOAD APP CALLED "PHONE INFO" FOUND HERE OR PLAY STORE Phone INFO ?Samsung? 3.4.3 APK
3. CLICK MENU BAR IN TOP LEFT CORNER
4. CLICK OTHER TOOLS
5. CLICK SERVICE MODE (ROOT)
MUST HAVE ROOT FOR THIS TO WORK
AND FROM THERE YOU CAN ACCESS GCF
IF YOU TURN GCF ON AND STILL NO NETWORK OR NO ROOT APPLICABLE
NOTE 4- I DOWNGRADE TO 4.4.4 AND IT WORKS RIGHT AWAY
GALAXY S5- FLASH A DIFFERENT MODEM FOR BYPASS MSL
NOTE 3- FLASH A DIFFERENT MODEM
THESE ARE THE ONLY 3 DEVICES THAT I HAVE EVER HAD ISSUES WITH.
ALL IVE DONE HAVE BEEN ONES THAT WERE BAD ESN SO THIS WORKS GREAT!!!
4G PROBLEM
I have not been able to show 4g instead of 3g. but one thing I know is when sprint devices are put into roaming mode, it shows 3g. When these phones get unlocked they are basically put into roaming mode, and by checking the data speeds especially with t-mobile the phone is very fast, much faster than 3g speeds! SO WHO CARES WHAT IT SAYS AT THE TOP LET THE CUSTOMER KNOW IF THEIR PLAN CONSISTS OF 4G DATA, YOU WILL GET IT!
SPRINT DEVICES ON METROPCS
I have had no luck at all using these sprint devices on metropcs as you must pair the sim with the imei and they constantly reject sprint imei's which is bs but hey, if anybody figures it out let me know!!!
if anybody needs anything else explained just inbox me and I will be glad to help. Soon I will be placing step by step tutorials on youtube so be ready!!!
Thx for all that I unlock note 3 sprint 3 m a go and I activate it for the customer
Under metro and it work without no prblome also the Internet Signal is better than CDMA phones It's shows H PLUS SO SPEINT WORKS WITH METRO
Old 07-11-2016, 04:47   #17 (permalink)
Member: 220595
Thanks Meter: 355
Sorry, this is a mistake
Enviado desde mi SM-N920T mediante Tapatalk
Old 07-12-2016, 21:29   #18 (permalink)
Member: 2428732
Thanks Meter: 22
most devices:
mobile networks
4G PROBLEM
i mad this video for all user
https://www.youtube.com/watch?v=g1u0...ture=*********
by musa12
Old 07-12-2016, 21:31   #19 (permalink)
Member: 2428732
Thanks Meter: 22
how to unlock sprint phone s4 s5 note 3 and more l720t l720on 5.0.1
i made this video for all users i hope that help
Old 08-12-2016, 16:49   #20 (permalink)
Member: 2099665
Originally Posted by GTrader View Post
You will not be able to get 4G / LTE in the USA on GSM carriers. G900P, N900P, N910P etc do not support 4g / LTE GSM bands. You will only be able to get 3G speed in USA with these sprint devices after you unlock them for domestic use.
True, Use Frequency Check to check phones for bands available in the phone hardware
Old 08-12-2016, 17:25   #21 (permalink)
Member: 220595
Thanks Meter: 355
Hello
What is frecuency check?
Old 09-03-2016, 07:42   #22 (permalink)
Member: 2612601
Thanks Meter: 20
I have confirmed on domestic unlocked Sprint S5, S6, Note 5 showing "3G" but speed tests pulling roughly 10mb down / 2mb up which is standard 4G speeds. Have not seen it hit the higher 20mb + down, but regardless it is getting 4G.
Old 09-05-2016, 08:08   #23 (permalink)
sunil1670's Avatar
Member: 1849215
Thanks Meter: 136
UNLOCK INSTRUCTIONS:
Direct Unlock:
1. Phone must be powered on.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and choose 'DM/DUN over HSIC'.
4. Reboot phone.
Or use 'Activate Diag' function from 'Repair' tab.
5. Connect USB cable, install drivers if needed.
6. Select Samsung diagnostic port in port settings.
7. Press 'Unlock' button.
Domestic Unlock:
1. Power on the phone.
2. Enable 'USB debugging' in 'Settings'-'Developer options',
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'.
3. Connect the phone to PC with USB cable, install drivers if needed.
5. Select device in ADB settings.
6. Press 'Unlock Domestic' button.
Operation: Unlock SPRNT
Selected model: SM-G900P
Selected port: COM20 Z3X BOX Serial Port
Software version: 26.6
Waiting ADB device... OK
Reading phone info...
Model: SM-G900P
Android version: 6.0.1
Product code: Not Active
Phone version: G900PVPS3CPE2
PDA version: G900PVPS3CPE2
CSC version: G900PSPT3CPE2
CSC country code: USA
CSC sales code: SPR
HW version: G900P.04
Phone S/N: 00000000000
Modem board: MSM8974PRO
RF cal date: 2014.05.06
IMEI:
Checking Super user right... true
Initialization AT RIL... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.26.6
but still emergency call
The Following User Says Thank You to sunil1670 For This Useful Post:
Old 09-05-2016, 17:44   #24 (permalink)
Member: 2620678
note 5 not showing up in z3x adb settings
Old 09-05-2016, 18:11   #25 (permalink)
Member: 2620678
Sm-n920p
This is what I get when I try to domestic unlock sprint galaxy note 5
exception: access violation at address 004074 E 0 in module
Samsung Tool Pro read of address 00000000
Done with Samsung Tool PRO v.24.3
Old 09-05-2016, 19:19   #26 (permalink)
Member: 2146046
Thanks Meter: 62
Originally Posted by yurais View Post
Hello
frequencycheck(dot)com
It is a website where you can check to see if phone will work on specific carriers for country. Also give you good info about phones frequencies / bands.
Old 09-05-2016, 19:30   #27 (permalink)
Member: 199814
Thanks Meter: 1,960
Link not working
Sent from my iPhone using Tapatalk
Old 09-28-2016, 03:49   #28 (permalink)
kachman's Avatar
Member: 272581
Thanks Meter: 118
Direct Unlock:
4. Reboot phone.
Domestic Unlock:
Model: SM-G900P
CSC sales code: SPR
IMEI:
Unlocking... OK
Unlock done
search for G900PVPU3CPCA_G900PSPT3CPCA_SPR.zip and flash it
Old 09-28-2016, 17:22   #29 (permalink)
papu3090's Avatar
Member: 852566
Thanks Meter: 464
Searching Samsung modem... detected COM286
Reading phone info... OK
Model: SM-J700F
AP version: J700FXXU2BPH4
CSC version: J700FODD2BPH2
CP version: J700FXXU2BPH2
Product code: SM-J700FZKDINU
Phone SN: R58H22ASWYN
Unique number: C00008A494F75C2
Reading IMEI... OK
IMEI: 353972077573932 (SIGN: OK)
IMEI Slave: 353973077573930 (SIGN: OK)
Reading data from phone... OK
Unlocking... OK
Unlock done
Done with Samsung Tool PRO v.26.8
Old 11-08-2016, 11:22   #30 (permalink)
Member: 269969
Thanks Meter: 3
It does not work unlock
Waiting ADB device... ok
Model: SM-G925P
Phone version: G925PVPS4CPJ1
PDA version: G925PVPS4CPJ1
CSC version: G925PSPT4CPJ1
CSC sales code: XAS
HW version: G925P.02
Phone SN: 00000000000
Modem board: MDM9635M
RF cal date: 2015.10.15
IMEI:
Writing AT RIL... ok
Initialization AT RIL... root required
Initialization AT RIL... ok
Unlocking... ok
Rebooting phone... ok
Unlock done
Done with Samsung Tool PRO v.27.1
The Following User Says Thank You to ostapchikyra For This Useful Post:
Page generated in 0.23084 seconds with 8 queries
