flash eng root and eng or regular modem from u4, and try again but from what others post z3x won't unlock it, have to use another tool after flashing root/modem - like gcpro modem must be from older firmware u4 - 2017 release |
Please give the combination link of G935P |
First, flash the phone with from combination from the OP or this: COMBINATION_FA60_G935PUCU6ARC1_IMEIAUTHORITY.COM.z ip https://androidfilehost.com/?fid=746163614322266293 Second, unlock using any box with model G935P, enable OEM Unlock if available under Developer Options. Third, flash with latest full stock. I usually select PIT/Repartition and enable NAND Erase under options. G935PVPU6CRE7_G935PSPT6CRE7_SPR_Sprint_USA_8.0.zip https://updato.com/firmware-archive-...15FA163EE8F90B Quote:
https://combinefile.com/index.php?a=...=file&id=28825 |
The device is G935P after flash Combination file change to G935A, but when i reflash , I have to flash with G935A ro G935P? |
g930p u6 frp plz help me |
Samsung G935P RG3 unlocking Solution any one had succesfully unlock G935P RG3 (8.0), i need the Combination File. if anyone has please do send me the link. |
post ur phone build here we easy to help u loke bit 4 or bit 5 or bit6 |
R16.NWG935PVPU7CRG3 This is the build number |
can we use on Octoplus Samsung to unlock G935P . if yes its same way to do it ?? |
I have a g935p with 8.0 can I unlock with another combination? this one did not work |
You may be able to flash U6 or U5 modem file from combination then try Unlock otherwise have to wait |
SM-G935P sprint unlock error Waiting ADB device... OK Reading phone info... Model: SM-G935P Android version: 7.0 PDA version: G935PVPU5BQL1 CSC version: G935PSPT5BQL1 Phone version: G935PVPU5BQL1 Product code: Not Active CSC country code: USA CSC sales code: SPR Phone SN: 00000000000 IMEI: 357090072614829 HW version: REV0.7 RF cal date: 2016.08.22 Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-12-01 Boot Warranty bit: 0 Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... false Super user right required true Initialization AT RIL... error (5) Done with Samsung Tool PRO v.33.5 HELP ME PLEASE !!!!!! |
flash combination file or flash combination file's modem |
thank you it work for me S7 EDGE SPRINT SUCCEFFUL UNLOCK FLASH COMBINATION_FA60_G935PUCU6ARC1_IMEIAUTHORITY.COM UNLOCK WITH Z3X DONNE THAN FLASH FULL FIRMEWARE WITH Z3X (field to flash with odin ) |
