Old 02-01-2018, 05:12   #76 (permalink)
Member: 566229
Thanks Meter: 7
Friends this is where I'm at flashed with G935a combination file and then unlock worked. The phone now says G935A , but now I can't flash back to G935P stock any ideas
Old 02-01-2018, 16:43   #77 (permalink)
Member: 92260
Thanks Meter: 807
Follow this carefully...
Flash Rev-5 combi (it will show ATT which is fine)
Unlock
Reflash with Rev-5 full stock, preferably the "U" firmware (less bloat-ware)
Must try both normal and patched Odin for both flashes.
Old 02-01-2018, 17:25   #78 (permalink)
Member: 2596108
Thanks Meter: 57
Originally Posted by azzzzel View Post
yes i will pm , i cannot share links yet
hey what method without flashing combo or tripping knox do you have that will work for Z3X? because only gck can do it with engroot
Old 02-02-2018, 00:56   #79 (permalink)
Member: 1331962
Thanks Meter: 3
i used chimera with engroot.
Sent from my SM-G930T using Tapatalk
Old 02-02-2018, 01:38   #80 (permalink)
Member: 2596108
Thanks Meter: 57
Interesting. Even Chimera can unlock but not z3x that is nuts. But good to know thank you
Old 02-04-2018, 01:48   #81 (permalink)
Member: 1537420
Sonork: 100.1653338
Thanks Meter: 5
Originally Posted by obliviousmnd View Post
its out. check here
G935PVPU5BQJ3 New Binary Need
Mine is N950u from sprint with Dec 1 2017 android security patch level.The software version is N950USQU2BQLA.Please which combination file should I use?Thanks.
Old 02-04-2018, 06:10   #82 (permalink)
Member: 2796441
Thanks Meter: 9
I think this Binary will eligible for your current binary version.
Its BL2 Factory binary and your stock binary also has BL2.
Old 02-04-2018, 06:56   #83 (permalink)
Member: 2309595
Thanks Meter: 102
Yes. Flash bin 2 combination and then unlock. I tried and it work fine
Old 02-05-2018, 01:08   #84 (permalink)
Member: 1537420
Sonork: 100.1653338
Thanks Meter: 5
@SMN9999.You think?You mean you are not sure?It is a customer's phone and I don't want to brick it.I want to be sure that the combination file will work with the build I have before doing anything.Thanks.
Old 02-05-2018, 01:14   #85 (permalink)
Member: 1537420
Sonork: 100.1653338
Thanks Meter: 5
Is your build the same as mine?
Old 02-05-2018, 01:16   #86 (permalink)
Member: 1537420
Sonork: 100.1653338
Thanks Meter: 5
Old 02-05-2018, 03:43   #87 (permalink)
Member: 1307456
Thanks Meter: 45
Any solution for the g930p b5, do u have the combination file?
Old 02-05-2018, 04:14   #88 (permalink)
Member: 2796441
Thanks Meter: 9
I want to confirm this, but I don't have N950 sprint model.
But I have seen many successful unlock information in this forum.
Hence I ADVISED to you. Not instruction. So I mentioned "THINK",
Remain things you decide it.
As you feel, I'm normal user of this forum. I just helped to you by my background knowledge which acquired information from this Z3X forum.
If you need official state from Z3X team about your question, please wait and do that.
But whatever selected,any result occurred even if Good result or Fail result, The responsibilities are only you.
Thanks
Old 02-05-2018, 13:07   #89 (permalink)
Member: 482218
Thanks Meter: 108
that is what this thread is about. read previous messages.
Old 02-08-2018, 19:34   #90 (permalink)
Member: 2802156
Thanks Meter: 166
flash the g935a combination from the shell/z3x files, unlock, then flash back stock g935p, currently only att and sprint have u5 bit rev, can't flash g935U or g935T they're on u4
The Following User Says Thank You to gsm_service4u For This Useful Post:
Page generated in 0.37706 seconds with 8 queries
