Old 05-23-2018, 02:48   #121 (permalink)
lolo24's Avatar
Member: 2572618
Thanks Meter: 180
Here is Combination Firmware Binary 6 For Unlock.
https://androidfilehost.com/?fid=746163614322266293
BestRegards.
Luis Manresa
The Following 8 Users Say Thank You to lolo24 For This Useful Post:
Old 05-23-2018, 05:27   #122 (permalink)
Member: 199355
Thanks Meter: 19
nice refference sir thank for this................
Old 05-23-2018, 06:10   #123 (permalink)
Member: 2825342
Thanks Meter: 11
i need for root bit 6
Old 05-25-2018, 06:46   #124 (permalink)
Member: 1634153
Thanks Meter: 13
no signal after flash full firmware,help plss
Old 05-25-2018, 09:05   #125 (permalink)
Member: 1084045
Thanks Meter: 35
Thank you. Tested and worked like a charm
Old 05-25-2018, 20:03   #126 (permalink)
Member: 2592628
Thanks Meter: 206
hardware issue
not issue with unlock, issue with phone. *#0011# check mipi
The Following User Says Thank You to obliviousmnd For This Useful Post:
Old 06-10-2018, 22:31   #127 (permalink)
saiful2001's Avatar
Member: 5509
Sonork: whatsapp : +8801612000020
Thanks Meter: 186
Dear friend,
Any solution to fix this.
i face the problem now.
Old 06-12-2018, 19:29   #128 (permalink)
doomstyle's Avatar
Member: 6879
Thanks Meter: 31
g935p how to unlock it via z3x
hey bros i have a s7 lock to sprint how to unlock it via z3x
Old 06-12-2018, 20:21   #129 (permalink)
Member: 2616438
Thanks Meter: 143
Flash combination and unlock
The Following User Says Thank You to wadda7o For This Useful Post:
Old 06-13-2018, 22:01   #130 (permalink)
hq15955657's Avatar
Member: 2721132
Thanks Meter: 35
this the one of the correct way.
Old 06-21-2018, 00:49   #131 (permalink)
Member: 2271672
i have this problem ........
Old 06-21-2018, 13:42   #132 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
G930P binary U6 unlock file plz needed
Old 06-26-2018, 08:48   #133 (permalink)
Member: 12427
Thanks Meter: 76
Originally Posted by suhaib_karjah View Post
Operation: Unlock
Selected model: SM-G935P
Software version: 31.5.1
Waiting ADB device... OK
Reading phone info...
Model: SAMSUNG-SM-G935A
Android version: 6.0.1
PDA version: FA60_G935AUCU6ARC1
CSC version:
Phone version: G935AUCU6ARC1
Product code: Not Active
CSC country code:
CSC sales code:
Phone SN: 00000000000
IMEI: 35709007xxxxx
HW version: REV0.7
RF cal date: 2016.10.31
Chip name: MSM8996
Modem board: MSM8996
Security patch: 2016-01-01
Boot Warranty bit: 0
Incorrect model selected. This may damage your phone. Continue? Yes
Writing AT RIL... OK
Initialization AT RIL... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.31.5.1
first Download COMBINATION file G935A u6 then flash it and chose on z3x G935p then Unlock
last flash full firmware here
https://mega.nz/#!D1xmnTAZ!kmRM51MYu...S5v01n2mWGXivs
Did you have signal after unlock?
Old 06-27-2018, 10:09   #134 (permalink)
Member: 2405015
Thanks Meter: 3
PLZ help G935P U6 unlock error
i have g935p u6 i tried to unlock it but it fails i triedon combination it says done but still not unlocked
Operation: Unlock
Software version: 32.7
Model: SM-G935P
Android version: 7.0
PDA version: G935PVPU6BRD2
CSC version: G935PSPT6BRD2
Phone version: G935PVPU4APL6
Product code: SM-G935TZDAXAS
CSC country code: USA
CSC sales code: XAS
Phone SN: RF8H5018TZY
IMEI: 356164072927704
HW version: REV0.7
RF cal date: 2016.05.03
Chip name: MSM8996
Security patch: 2018-03-01
Unlocking... error
Done with Samsung Tool PRO v.32.7
Old 06-30-2018, 17:55   #135 (permalink)
Member: 92260
Thanks Meter: 808
Originally Posted by kumkon View Post
Dear friend,
Had the same problem, solution is to do full reset via ##786# + SPC
SPC can be read either by USB RIL while rooted or through uart
If you're still getting a MIPI Fail error under *#0*#, then do the following in this order:
Try re-flashing it with full stock 4-file, and NAND Erase turned on in Odin's Options menu.
Try restoring original EFS while rooted, hopefully had it saved earlier during unlock.
It can be due to bad main board but more likely a bad charging port, try replacing the entire charging port circuit board.
The Following User Says Thank You to BillA For This Useful Post:
Page generated in 0.38649 seconds with 8 queries
