06-04-2017, 05:19 | #2 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | no need full flash just downgrade your modem version.problem will be solved . |
The Following User Says Thank You to kothamamun For This Useful Post: |
06-04-2017, 05:35 | #3 (permalink) |
Junior Member Join Date: Oct 2014 Location: syria
Member: 2274039 Status: Offline Thanks Meter: 2 | Dawongred 6.0.1 and flash boot combination and reset frp by z3x Sorry English letel أرسلت بواسطة iPhone بإستخدام Tapatalk |
The Following User Says Thank You to omardam33 For This Useful Post: |
06-04-2017, 05:37 | #4 (permalink) |
Member: 2274039 Status: Offline Thanks Meter: 2 | أخي قم بعمل داونجريد للإصدار السابق 6.0.1 وبعدين نزل كمبنيشين وفلش منها بوت فقط واذا لم تنجح قم بتفليش بوت و اس بوت وبعدها اعمل reset frp على بوكس z3x أرسلت بواسطة iPhone بإستخدام Tapatalk |
06-09-2017, 09:03 | #5 (permalink) |
Crazy Poster Join Date: Jun 2012 Location: Sibiu Age: 31
Member: 1776557 Status: Offline Thanks Meter: 3 | Operation: Reset FRP/React/EE Selected model: SM-G930F Software version: 28.2 Checking local file... not found Searching server... Ok Downloading file... Ok Checking local file... Ok Searching USB Flash interface... COM40 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Model: SM-G930F Android version: 7.0 Product code: Phone version: PDA version: G930FXXU1DQD7 CSC version: G930FDBT1APE2 CSC country code: Germany CSC sales code: DBT HW version: Phone SN: R58H34A8BBJ Chip name: EXYNOS8890 Modem board: Security patch: 2017-04-01 RF cal date: IMEI: Checking Super user right... true Erasing FRP... Ok Checking local file... not found Searching server... Ok Downloading file... Ok Checking local file... Ok Restoring kernel... Ok Rebooting phone... Ok Reset FRP done Done with Samsung Tool PRO v.28.2 no root,only flash with smart switch after frp reset |
06-25-2017, 13:46 | #6 (permalink) |
No Life Poster Join Date: Dec 2005 Location: RIFF-XILINX
Member: 214827 Status: Offline Sonork: 100.1597158 Thanks Meter: 59 | Operation: Reset FRP/React/EE Selected model: SM-G930F Software version: 28.2 Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM14 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Waiting ADB device... timeout Phone not found Done with Samsung Tool PRO v.28.2 At No of my joining and on 8 with firmware tried .. versions Thanks. |
08-01-2017, 15:50 | #7 (permalink) |
Freak Poster Join Date: Oct 2003 Location: noahabahama Age: 44
Member: 41229 Status: Offline Thanks Meter: 24 | use "reset frp ufs" Searching Samsung modem... wykryty COM24 Czytanie informacji z telefonu... Ok Model telefonu: SM-G930F AP wersja: G930FXXU1DQEF CSC wersja: G930FDBT1DQD1 CP wersja: G930FXXU1DQD7 Kod produktu: DBT Telefon SN: R58H4297A9J Numer niepowtarzalny: 9885E6485539523038 Odczytuję IMEI... Ok IMEI: 35 (SIGN: OK) Ukończono Samsung Tool PRO v.29.0 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Sprawdzanie telefonu na COM3 Ok Phone detected, do not release 'Vol down' Czytanie danych z telefonu... Ok Release 'Vol down' now Comparing selected model... match (G930F) Ustawienia połączenia... Ok Reseting FRP... Ok Restart telefonu... Ok Reset FRP zrobione Ukończono Samsung Tool PRO v.29.0 |
08-22-2017, 10:39 | #8 (permalink) |
Junior Member Join Date: May 2015
Member: 2394281 Status: Offline Thanks Meter: 0 | hello NESTOR7 Jakim kablem robiłeś to przez ufs bo ja siedzę nad bydlakiem już 4 godz i pokazuje na combination 6.0.1 że frp zrobione i prosi o fabrykę , niestety w trybie download info że FRP ON a Po wgraniu 4 plikowego flasha dalej się upomina o konto ?? Jakieś pomysły . ?? |
08-22-2017, 13:11 | #9 (permalink) |
Member: 41229 Status: Offline Thanks Meter: 24 | rj45 do z3x a ten sam co do s5610 fbus oczywiscie. soft musi byc oficjalny, combined nie zadziala.. soft wrzuc smart switcchem. musi isc Last edited by Nestor7; 08-22-2017 at 13:17. |
03-05-2018, 20:53 | #10 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2154724 Status: Offline Thanks Meter: 2 | Used Z3X BOX UART AUTO cable, through box RJ45 worked 1st time Operation: Reset FRP UFS Selected model: SM-G930F Selected port: COM25 Z3X BOX Serial Port Software version: 30.8 Done with Samsung Tool PRO v.30.8 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM25 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G930F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done |
