06-28-2016, 14:45 | #31 (permalink) |
Major Poster Join Date: Oct 2013 Location: The Tundra
Member: 2048233 Status: Offline Thanks Meter: 51 | Can somebody PM how to flash to AT&T/T-MO? Thanks |
06-30-2016, 15:14 | #37 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | You can try installing SuperSU by: adb root adb shell mount -o remount,rw /system rm -fR /system/app/*Knox* ... then install SuperSU binaries ... Now, the problem is that after some testing on a couple of ATT S7 models, it turns out that every stock TAR package also has a "meta-data\1.mf" file which contains a signature for each file hashed with SHA256 encryption, causing the BOOT file flashing to fail. If anyone knows how to generate such signature please share it. Another possible way is to flash a leaked engineering ABOOT or FACTORY binary first, then the BOOT file which is compatible, but keeps failing due to the stronger bootloader security in the ATT S7 models only... for now |
The Following User Says Thank You to BillA For This Useful Post: |
06-30-2016, 16:27 | #38 (permalink) |
Member: 2048233 Status: Offline Thanks Meter: 51 | Confirmation on the 935T Okay, I can confirm this works for unlocking PE1 on the G935P; and I can confirm that the file can be flashed on a G935T, but being as the model isn't supported yet on SPT, I don't have a procedure to run to check if it can be unlocked. |
07-01-2016, 07:40 | #39 (permalink) | |
Major Poster Join Date: Aug 2008 Location: MX
Member: 835563 Status: Offline Thanks Meter: 22 | Quote:
07-03-2016, 17:38 | #40 (permalink) | |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | Quote:
Hey mate to unlock G935T even with or without root you have to wait for a long time even for a year because After 1 to 2 years there is no exploit find for qualcomm device app lock And S7 tmobile/metropcs also have qualcomm chipset As example g360t,g530t, etc are qualcomm and no unlocking available for it But g925t,g928t,g920t,and n920t etc all are exynos chipset and its unlocking is available because of EXYNOS The only way to unlock it by online unlocking server Br Shahzaib Jahangir | |
07-03-2016, 17:40 | #41 (permalink) | |
Member: 2048233 Status: Offline Thanks Meter: 51 | Quote:
07-04-2016, 20:53 | #42 (permalink) |
Member: 92260 Status: Offline Thanks Meter: 843 | Full root on ALL S7 QC models G930A+Z/G935A+Z, G930P/G935P, G930T/G935T, G930V/G935V Those who are looking for full root on all S7 QC models, here it is: http://forum.gsmhosting.com/vbb/11909856-post61.html |
The Following 3 Users Say Thank You to BillA For This Useful Post: |
