Stylo 2 LS775-V9 Unlock Done Z3X 100% Please see the attached firmware and the link below. This works on Sprint virgin and boost LG Stylo 2 ls775 this is version v9 software. This is a very straight-forward unlock requires very little knowledge all you have to do is Flash this file to the phone and it auto unlocks and the APN works. All you have to do is put the phone in download mode by holding the volume up and plugging the unit into your computer. Proceed to install the drivers for LG if you do not have them and then flash this tot file with z3x. I have only had success with z3x for this file. The phone will never relock even if it updates the update will fail and say error. Please don't forget to say thanks enjoy the download guys. https://mega.nz/#!OgJVQQJT!PnMesLoy_...LOPBA4iQcTDFWU I hope this helps someone do something similar for the ls777v8 Stylo 3 soon I have tried all methods with the new V8 software and I have failed so for. Sent from my LG-LS777 using Tapatalk |
I will try later today. Thank you so much! Sent from my iPhone using Tapatalk |
Thank you big sharring. |
I tried the file u sent me.. Apparently, it is still the same problem as before. It shows the carrier in about less than 2 secs then went back to service disabled. This is the same problem before I flashed the file u sent. I guess I'll try ZV8 then unlock. Sent from my iPhone using Tapatalk |
Yes.. LS775. https://uploads.tapatalk-cdn.com/201...c30f6ed98c.jpg https://uploads.tapatalk-cdn.com/201...d8a4ce4bb4.jpg Sent from my iPhone using Tapatalk |
Flashed the ZV9 firmware u sent.. https://uploads.tapatalk-cdn.com/201...89da71aa9b.jpg Same Service Disabled. Tried all Network Mode (GSM) Same problem.. Sent from my iPhone using Tapatalk |
Well that ****ed up my phone lol Quote:
@Andrew_tm https://drive.google.com/file/d/10-G...KgV_0JEQx/view This the LS775ZVB.TOT I did with firmware maker for your reference |
Hi guys ,can I flash this tot file on lg ls775 zva 7.0 nougat? Let me know please thanks |
I don't think you can flash the latest LG firmware maker made files because they are encrypted. |
You can also write zv9 instead of zva4. |
Sent from my SM-N910W8 using Tapatalk |
