01-29-2018, 14:30 | #1 (permalink) |
Freak Poster Join Date: Dec 2017 Location: Dar es salaam,Tanzania
Member: 2790329 Status: Offline Thanks Meter: 27 | Success story:repair imei on samsung sm-a510f done by z3x boz Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 8. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-A510F Software version: 30.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... Please, allow USB debugging on phone... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-A510F Android version: 7.0 Product code: SM-A510FZKFXSG Phone version: A510FDXXU4CQDL PDA version: A510FXXU4CQG7 CSC version: A510FDOJP4CQG1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.000 Phone SN: RF8H50WJ7TB Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-07-01 RF cal date: 20160510 IMEI: 356911071889008 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: DD AB C4 B2 FA 64 C7 3F 84 20 A0 67 EC 20 6B 76 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.30.5 Sent from my VFD 300 using Tapatalk |
