05-15-2016, 07:43 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: South Afrika Age: 33
Member: 2562097 Status: Offline Thanks Meter: 203 | sucessfully write cert done with king of box BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-G900F Selected port: COM18 SAMSUNG Mobile USB Serial Port Software version: 25.3 Checking certificate file... OK KEY ID: 0478 Waiting ADB device... OK Reading phone info... Model: SM-G900F Android version: 5.0 Product code: Not Active Phone version: G900FXXU1BOD3 PDA version: G900FXXU1BOE3 CSC version: G900FXFV1BOE4 CSC country code: South Africa CSC sales code: XFV HW version: Phone S/N: 00000000000 Modem board: MSM8974PRO RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0478 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.25.3 |
