Unlock Server
Old 05-22-2011, 15:45   #76 (permalink)
Member: 900685
Thumbs down is it a JOCK
Originally Posted by abdullah sheikh View Post
Hello Mr.blang thankx so much for sported T959 UNLOCKING
YES UNLOCKING IN TRUE
HERE IS PROCEDURE :
ON YOUR T959 CONNECT USB AUTO INSTALL DRIVERS
OPEN SHELL
PRESS RUN :
OPEN SOFT WARE
CLICK GET INFO
THEN PRESS UNLOCK
ON YOUR HAND SET WITH UN REGISTERED SIM CARD ENTER NET CODE
AND ENJOY AND PLEASE DO NOT FORGET PRESS THANKS
At start u show T then T959 and last software is showing I9000...are u fooling to people or fooling yourself???????????
Old 05-22-2011, 16:17   #77 (permalink)
Sudan-Mobiles's Avatar
Member: 281857
Sonork: 100.1600687
heheh it read like that .. he not fooling anybody..
Old 06-09-2011, 12:55   #78 (permalink)
generalbuzness's Avatar
Member: 1568781
t959 UNLOCK PROBLEM
Searching Android modem... detected (COM49)
Model: SGH-T959
CountryCode: ¹Ì±¹/TMB
Factory SW: UVJI6
UniqueNumber: 74180001947609
MemoryPhone: KB100D00WM(T959)
Phone SW: T959UVJI6
Phone S/N: 00000000000
IMEI: 35506004020044/1
Bypass MSL... error (flash patched firmware first)
Done with Samsung 3G tool ver 9.4
HELP
Old 06-09-2011, 13:08   #79 (permalink)
Member: 1568781
HOW TO UNLOCK T959
step by step
Old 06-09-2011, 19:13   #80 (permalink)
kaderlamine's Avatar
Member: 1186610
Count supported models - 218
File analysis... OK
Total File Size: 0x00C00000
Searching USB flash interface... detected COM53
Opening Port... OK
Setup connection... OK
Reading PIT From Phone... OK
Sending modem.bin... OK
Done with Samsung 3G tool ver 9.1
Searching Android modem... detected (COM138)
Model: SGH-T959
Factory SW: UVJI6
Phone SW: T959UVJE8
Bypass MSL... OK
Reading Security... OK
Calculating codes... OK (time - 00:00:00)
Freeze code: 00000000
NET lock: 00000000
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
kaderlamine
thankx
Old 06-30-2011, 13:25   #81 (permalink)
Member: 731317
Sonork: JASHAN4892@YAHOO.COM
how to open step by step pls
Old 06-30-2011, 15:40   #82 (permalink)
Member: 731317
File analysis... OK
Searching USB flash interface... not found
Searching Samsung USB interface... detected (COM21)
Model: SGH-T959V
SW: T959VUVKD1
IMEI: 35529904371667/8
File analysis... OK
File analysis... OK
Searching Android modem... detected (COM21)
Model: SGH-T959V
Factory SW: UVKB5
UniqueNumber: 76250001309891
MemoryPhone: KB100L00WM(T959V)
Phone SW: T959VUVKD1
IMEI: 355299043716678/8
File analysis... OK
Old 09-05-2011, 15:02   #83 (permalink)
kmaxmax's Avatar
Member: 553000
After rooted T959 it is giving error !
Checking ROOT... FALSE
Reading Phone Info... OK
Android Version: 2.1-update1
Model: SGH-T959
Product Code: SGH-T959ZKBTMB
Phone Version: T959UVJFD
PDA Version: T959UVJFD
CSC Version: T959TMBJFD
IMEI: 35180xxxxxxxxxx
Rooting Phones... OK
Restarting... OK
Done with Samsung Tool ver 10.7
Plz suggest me where i m wrong i already rooted my samsung T959 with the following method.
1. Download the attached zip and rename to: update.zip
2. On your device, navigate to Settings > Applications > USB settings and select Mass storage
3. Plug your device into your computer, select mount USB from your device's pull-down window
4. Copy the update.zip to the INTERNAL SD memory (~14gb on this drive,  not the one w/ Avatar if you've still got the 2gb SD card in)
5. Turn your phone off.
6. Hold down volume up and volume down while powering on the phone, this  should get you to a recovery menu, you may have to try this a few  times.
7. In Recovery menu select 'Reinstall Packages' (use vol_down then power to select)
Phone will reboot
what should i do here is the updated zip file attached with which i rooted my T959.
Kmaxmax
The Following User Says Thank You to kmaxmax For This Useful Post:
Old 09-07-2011, 15:57   #84 (permalink)
Member: 1454032
Sonork: 0923007852629..0622443355
Searching Android modem... detected (COM15)
Model: SGH-T959
Factory SW: UVJFD
UniqueNumber: 76300000334907
Phone SW: T959UVJE8
IMEI: 35180104590310/7
Bypass MSL... OK
NET lock: 00000000
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
Old 09-23-2011, 20:48   #85 (permalink)
Member: 372188
Starting ADB Server... OK
Model: SGH-T959
IMEI: 3518010477xxxxx
Reading Data From Phone... OK
Writing NV Data To Phone... OK
Calculating md5... OK
Writing md5 To Phone... OK
Rebooting... OK
Done with Samsung Tool ver 10.9
Thanks z3x box
Old 09-26-2011, 11:55   #86 (permalink)
Member: 407564
after so much try i done
Count supported models - 253
Searching Samsung USB Modem... Detected (COM40)
Model: GT-I9000
SW: T959UVJFD
IMEI: 351801047207929
Done with Samsung Tool ver 11.2
Model: SGH-T959
Rooting Phones... Error
Checking ROOT... TRUE
Rebooting... OK
Searching Samsung USB Modem... Not Found
Model: GT-I9000
SW: T959UVJFD
Searching Samsung USB Modem... detected (COM40)
Bypass MSL... Write Port Error
Model: SGH-T959
Getting Codes... OK
MCK: 08040627
NCK: 52742460 UNLOCKED
NSCK: 00000000 UNLOCKED
SPCK: 00000000 UNLOCKED
CPCK: 00000000 UNLOCKED
SIM: 00000000 UNLOCKED
Old 11-19-2011, 10:49   #87 (permalink)
Member: 1589326
1000%ok good solution abdulla sheukh
Old 12-09-2011, 11:38   #88 (permalink)
manzoor300's Avatar
Member: 817733
Sonork: 100.1605504
nice work good solustion thanks
Old 02-21-2012, 08:47   #89 (permalink)
R.G.mobiles's Avatar
Member: 1724303
Sonork: 1611265
Count supported models - 300
Android Version: 2.2.1
Model: SGH-T959V
Product Code: SGH-T959HAYTMB
Phone Version: T959VUVKD1
PDA Version: T959VUVKD1
CSC Version: T959VTMBKD1
IMEI: 355299045919114
Reading Data From Phone... Error
Done with Samsung Tool ver 12.1
Old 02-28-2012, 15:46   #90 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Count supported models - 302
Model: SGH-T959
Phone Version: T959UVKA2
PDA Version: T959UVKA2
IMEI: 351801043320924
Getting Codes... OK
Detected SHA1 Codes
Please Wait, Calculating Codes... OK (time - 00:00:41)
MCK: 97204853
NCK: 39620240 UNLOCKED
NSCK: UNLOCKED
SPCK: UNLOCKED
CPCK: UNLOCKED
SIM: UNLOCKED
Done with Samsung Tool ver 12.2
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.80389 seconds with 12 queries
