01-11-2013, 19:49 | #1 (permalink) |
Major Poster Join Date: Oct 2005
Member: 194429 Status: Offline Thanks Meter: 14 | AT&T I727 (4.0.4) Unlock Successful by rooting and using USB cable Z3X Software Version 13.8 OS version of the phone 4.0.4 Enable USB Debugging on the phone *#7284# Set the first option to MODEM Set the second option to MODEM *#9090# Set it to USB 1. Install a custom recovery and root the phone, follow this guide by vincom, he has made the rooting and custom recovery installation process a breeze, it'll take you 10mins or less to root the phone. (ROOT IS NECESSARY / MANDATORY) [HOWTO] NEWB GUIDES To: | RESTORE TO STOCK | USE ODIN | INSTALL CWM/TWRP | ROOT | - xda-developers 2. Use Z3X to read codes Here is the log of the operation ------------------------------------------------------------------------------------- Selected model: I727 Selected port: Selected port speed: 115200 Port not selected Done with Samsung Tool v.13.8 Selected model: I727 Selected port: COM21 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.13.8 Selected model: I727 Selected port: COM23 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M8260A-AABQOCZM-3.0.552067T Done with Samsung Tool v.13.8 Selected model: I727 Selected port: COM23 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M8260A-AABQOCZM-3.0.552067T Reading security... error access denied Done with Samsung Tool v.13.8 Selected model: I727 Selected port: COM23 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M8260A-AABQOCZM-3.0.552067T Reading security... error access denied Done with Samsung Tool v.13.8 Selected model: I727 Selected port: COM21 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... PDA/CSC version: I727UCLI3/I727ATTLI3 Phone version: SW VERSION :None Phone HW: REV0.2 Cal date: 2012.07.06 IMEI: 35990304216463 Phone S/N: R21C70Q3ZX Build: M9200B-SCAQCSZD-3.4.701084 Reading security... OK Searching server... error () Done with Samsung Tool v.13.8 Selected model: I727 Selected port: COM21 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... PDA/CSC version: I727UCLI3/I727ATTLI3 Phone version: SW VERSION :None Phone HW: REV0.2 Cal date: 2012.07.06 IMEI: 3599------------ Phone S/N: R21C7------ Build: M9200B-SCAQCSZD-3.4.701084 Reading security... OK Searching server... OK NET lock: #7465625*638*13146316# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.13.8 |
The Following User Says Thank You to ..::..DynafiX::.. For This Useful Post: |
