02-17-2017, 09:41 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Inside Samsung Pocket Age: 40
Member: 489331 Status: Offline Thanks Meter: 1,141 | AT&T S7 Edge G935A Unlock Done with MSL AT&T S7 Edge G935A Unlock Done with MSL |
The Following 2 Users Say Thank You to raulka2003 For This Useful Post: |
04-30-2017, 03:06 | #10 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Sprint and most providers will not let you unlock your phone by the MSL does not unlock it so it can be used on other networks. Back on track, as long as you are on a contract or making payments on the phone. The MSL just allows you access to dangerous menus that could actually screw your device up if you set something wrong. It would also not be covered by warranty if you needed to get your screw up repaired. Easy way if you have another phone to activate your old phone then reactivate your note through the sprint website. The website will give you a 6 digit code that says you may need to activate. That's your MSL The MSL unlock and SIM unlock are not the same thing. The MSL unlock just gives you access and ability to edit that service menu and nothing else. I use an APP called SPCUtility Does Z3X give you the MSL code? |
