12-23-2013, 13:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 666540 Status: Offline Thanks Meter: 354 | T679M unlock problem please help Selected model: T679 Selected port: COM30 SAMSUNG Android USB Diagnostic Serial Port (WDM) Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.16.3 I have tried this method: 1. enter *#7284# and select MODEM, restart the phone 2. enter *#9090# and select USB, restart the phone now connect phone to pc, install drivers.. In Samsung tool 11.6 select model T679 and under port select Samsung Android USB diagnostic and click unlock... http://forum.gsmhosting.com/vbb/f453...e-z3x-1442309/ but not succeed I have also changed usb port... also tried with rj45 C3300k cable... but still the same result Reading phone info... no answer from phone:conf used: |
12-23-2013, 13:47 | #4 (permalink) |
Freak Poster Join Date: Oct 2012 Location: TURKEY
Member: 1823773 Status: Offline Sonork: 100.1622605 Thanks Meter: 97 | 1- Pls use latest software Samsung Tool 16.7 2- phone factory data reset and wipe. 3- Pls use uart cable c3303k select z3x port click unlock |
12-23-2013, 13:52 | #5 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Uttara, Dhaka, Bangladesh Age: 48
Member: 524399 Status: Offline Sonork: 100.1602681 Thanks Meter: 86 | Quote:
my dear use uart cable | |
12-23-2013, 15:37 | #7 (permalink) |
Member: 1823773 Status: Offline Sonork: 100.1622605 Thanks Meter: 97 | Type *#7284# and choise phone usb. Type *#197328640#, select: Common - Diag Config - USB diag. Reboot phone. try it usb mode Last edited by ifactoryunlocked; 12-23-2013 at 15:45. |
02-07-2014, 19:14 | #11 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Kathmandu,Nepal Age: 46
Member: 983663 Status: Offline Sonork: 100.1623270 Thanks Meter: 551 | Happy to see problem solved by your own hard work, its also good record for Z3x team. Thanks for all work & post |
The Following User Says Thank You to snmobilecenter For This Useful Post: |
