03-26-2010, 19:02 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: lisbon Age: 34
Member: 98881 Status: Offline Thanks Meter: 26 | is there is any bug in d980s flash files ?? i want to put russion langueage in d980 so then i flashed D980XEHJ1 and phone come with english french and some arbic langueages and after that i flashed D980XEHJ6 still same langueages and after D980XEHL1 and still same langueges. and after that i tried to flash back portuguease langueage because phone befor have portuguease so to i give phone back to client i have to put back portuguease langueage. thats why i flashed D980XCHJ3 and still same english french and some arbic or urdo langueges in phone. so please to solve ma probelem give me compleat and good solusion to put russion or portuguese languege on phone. so please any z3x suporter please help me. its samsung d980s. will wait for answer. |
03-26-2010, 19:11 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
03-26-2010, 19:47 | #3 (permalink) |
Member: 98881 Status: Offline Thanks Meter: 26 | Selected model: D980_s Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 4541 Sending loader2... OK Flash ID: 00EC2206000100000034 Slave Detected Sending slave loader1... OK ARM version slave 4541 Sending slave loader2... OK Flash ID: 00EC220600010000E1D0 NAND format - ок Start NOR flash NOR flash - ok Start Flash TFS Mount NAND - ok Create DIR - ok Download - ok Elapsed time: 379 second, sw ver: 3.4.0034 ------------------------------------------------------------------------------- Selected model: D980_s Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 4541 Sending loader2... OK Flash ID: 00EC2206000100000034 Slave Detected Sending slave loader1... OK ARM version slave 4541 Sending slave loader2... OK Flash ID: 00EC220600010000E1D0 NAND format - ок Start NOR flash NOR flash - ok Start Flash TFS Mount NAND - ok Create DIR - ok Download - ok Elapsed time: 377 second, sw ver: 3.4.0034 ------------------------------------------------------------------------------- Selected model: D980_s Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 4541 Sending loader2... OK Flash ID: 00EC2206000100000034 Slave Detected Sending slave loader1... OK ARM version slave 4541 Sending slave loader2... OK Flash ID: 00EC220600010000E1D0 NAND format - ок Start NOR flash NOR flash - ok Start Flash TFS Mount NAND - ok Create DIR - ok Download - ok Elapsed time: 380 second, sw ver: 3.4.0034 ------------------------------------------------------------------------------- Selected model: D980_s Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 4541 Sending loader2... OK Flash ID: 00EC2206000100000034 Slave Detected Sending slave loader1... OK ARM version slave 4541 Sending slave loader2... OK Flash ID: 00EC220600010000E1D0 NAND format - ок Start NOR flash NOR flash - ok Start Flash TFS Mount NAND - ok Create DIR - ok Download - ok Elapsed time: 372 second, sw ver: 3.4.0034 |
03-26-2010, 19:49 | #4 (permalink) | |
why you not flash master part of phone.? | |
03-26-2010, 20:10 | #5 (permalink) |
Member: 98881 Status: Offline Thanks Meter: 26 | which master part sir ?? when i select master files .cla and .tfs flash fail and phone compleatly dead and when i flash slave file .cla and .tfs then 100% flash compleat and phone come alive but no language chang help me sir how to flash master part |
03-26-2010, 22:58 | #6 (permalink) | |
D980_S slave part. need flash each part. for each part exist dif flash files. | |
03-29-2010, 13:46 | #7 (permalink) |
Member: 98881 Status: Offline Thanks Meter: 26 | sir why u dnt help me compleat ?? is it so dificult to u help proper ur customers ?? i dnt know how to solv this thats why asking for help. please help me what u mean by this ?? D980_M master part D980_S slave part. need flash each part. for each part exist dif flash files. this mean to flash first two master files and after compleat flash 2 slave files ?? iam doing this but in flashing master files by selecting d980m its never compleat the flash always fail like this : Selected model: D980_m Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 4541 Sending loader2... OK Flash ID: 00EC2206000100000034 NAND format - ок Start NOR flash NOR flash - ok Start Flash TFS Mount TFS - ok Create DIR - ok TFS - Fail Send TFS - fail Elapsed time: 1476 second, sw ver: 3.4.0034 and after i flash slave files and in slave flashing i select d980s model and then compleat the flash 100% and phone power on and still no languege change. same english and somthing urdo. please give me good explained solution tio help me this probelem sir. or please add me on msn or give me ur msn to i contact to you to solve ma probelem sir. thanks again. ma msn and email is [email protected] |
03-30-2010, 12:51 | #9 (permalink) | |
inside d980 2 phones. D980_s and D980_m flash arhiv have inside flash files for each part slave and master. if you have error TFS flashing - check option - format tfs. | |
is there is a bug in banda 1.1.5.....[SOLVED] | topcom37 | PolarBox 3 | 6 | 02-06-2010 19:55 |
Is There Any Bug in "SagemEG_v9.2" ? | .::Skylinks::. | SAGEM JTAG UNLOCKER | 7 | 12-24-2008 11:33 |
is there is any manual to install red box | syrian | Redbox | 1 | 10-21-2005 22:05 |
is there a any hex file for sagem clip? | ^ares^ | Infineon C16X M51 & ARM7 M52 BASED | 2 | 05-30-2002 18:41 |
