08-27-2015, 00:12 | #1 (permalink) |
Freak Poster Join Date: Jun 2011 Location: NYC
Member: 1590407 Status: Offline Thanks Meter: 145 | Tmobile n910t 5.0.1 OG2 imei repair / no root no downgrade Selected model: SM-N910T Selected port: COM248 SAMSUNG Mobile USB Serial Port Software version: 22.3 Checking certificate file... OK KEY ID: 0772 Waiting ADB device... OK Reading phone info... Model: SM-N910T Android version: 5.0.1 Product code: SM2N910TZKETMB Phone version: N910TUVU1COG2 PDA version: N910TUVU1COG2 CSC version: N910TTMB1COG2 CSC country code: USA CSC sales code: TMB HW version: REV1.1 Phone S/N: RF8G61YR8CE Modem board: MDM9225M RF cal date: 2015.06.22 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0772 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Last edited by chaudhfa; 08-27-2015 at 00:16. Reason: SPELLING MISTAKE |
The Following User Says Thank You to chaudhfa For This Useful Post: |
10-10-2015, 11:33 | #3 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2310265 Status: Offline Thanks Meter: 0 | Hey bro How did you do it???? Do you need to reset efs? I've tried already and i have no success..... I tryed to downgrade to NK4 and still no success..... could you share your experience? thanks |
10-10-2015, 13:40 | #4 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Research new security on Samsung devices. There's a conditional statement that has to do with KNOX. |
The Following User Says Thank You to ecs87 For This Useful Post: |
10-10-2015, 14:54 | #5 (permalink) |
Member: 1590407 Status: Offline Thanks Meter: 145 | Esc87 is 200% correct on that ...Mess w Knoxx and thats it you will be be stuck n downgrading will be only other option Last edited by chaudhfa; 10-10-2015 at 14:54. Reason: Spelling mistake |
10-10-2015, 21:59 | #6 (permalink) |
Member: 2310265 Status: Offline Thanks Meter: 0 | yeah customer came already rooted with knox tripped. so i tried everithing already i had downgraded from OG2 to NK4 and no luck...... I tried custom rom using custom recovery and same result..... I also got a lot of 8 note 4 5.0.2 OG2 baseband waiting for repair..... but thanks anyway. |
11-13-2015, 12:52 | #8 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Nothing to do with Knox, had the exact same problem. After hours of trying finally realized that recovery showed version NH1 while the phone info showed OG2. So obviously there was some mismatch due to some amateur unlocker's attempt, so by simply reflashing with stock NK4 (or higher) it worked just fine. Here's the proof: Operation: Unlock Selected model: SM-N910T Selected port: COM3 SAMSUNG Mobile USB Serial Port Software version: 23.3 Reading phone info... Reading IMEI... OK IMEI: 35609506703xxxx Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done |
11-14-2015, 04:23 | #9 (permalink) |
Freak Poster Join Date: Aug 2011 Location: New York City
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | So did you check old security because you have to be rooted to do the new security?. It doesn't reset. Could you give more details? Was knox tripped? Thanks for sharing and not being greedy like its a verizon cert or something..lol everyone can do this but knowing this will save people 6 minutes for a flash. |
11-14-2015, 04:23 | #10 (permalink) |
11-16-2015, 07:50 | #12 (permalink) |
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | It doesn't work. Ecs could you help. Google isn't the best search engine. I had a pro that said he could do it. Got on teamviewer and couldn't do it either. Lol. Anyone.? I know it says checking preload data in recovery when I factory reset. |
11-17-2015, 22:46 | #13 (permalink) |
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | Well since there are so many greedy people then 20$ for the first person that can show me they can do it. I had three people try to do it over team viewer and they failed!!!! Free 20$ for the so called couple minutes in which you could do it. Thanks. Remember greed will consume you.!!! Its not like i cant do a note 4. I just dont like to downgrade. When i do the m thing it hangs on bypass msl. Anyone want a quick 20 on teamviewer? Holla...lol For instance selling a 5000$ solution that got solved buy z3x and others...lol |
11-20-2015, 03:58 | #15 (permalink) |
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | They wont answer. They think they are getting something out of it. There were times where they asked people questions. Yes google can help but you can only put so many key words before you realize that you have to spend hours upon days to find the solution. Question. Did you wipe the imei to zero while on OG2? |
