08-28-2010, 09:07 | #1 (permalink) |
Insane Poster Join Date: Sep 2008
Member: 865766 Status: Offline Thanks Meter: 3 | Model: SGH-T359 ount supported models - 201 Searching Samsung USB interface... detected (COM4) Model: SGH-T359 SW: T359UVJE1 IMEI: 35242204111851/4 ----------------------------- No answer from phone Error read info ----------------------------- No answer from phone Error read info Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found ----------------------------- No answer from phone Error read info ----------------------------- No answer from phone Error read info ----------------------------- No answer from phone Error read info Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... not found Searching Samsung USB interface... detected (COM4) Model: SGH-T359 SW: T359UVJE1 IMEI: 35242204111851/4 ----------------------------- Enable to open COM63 Error read info ----------------------------- No answer from phone Error read info ----------------------------- No answer from phone Error read info ----------------------------- No answer from phone Error read info Select file first Searching Samsung USB interface... detected (COM4) Model: SGH-T359 SW: T359UVJE1 IMEI: 35242204111851/4 Searching Samsung USB interface... detected (COM4) Model: SGH-T359 SW: T359UVJE1 IMEI: 35242204111851/4 Searching Samsung USB interface... detected (COM4) Model: SGH-T359 SW: T359UVJE1 IMEI: 35242204111851/4 Reading codes... OK SIM lock: 00000000 Phone lock: 00000000 ----------------------------- No answer from phone Error read info ----------------------------- No answer from phone Error read info ----------------------------- No answer from phone Error read info No answer from phone Searching Samsung USB interface... detected (COM4) Model: SGH-T359 SW: T359UVJE1 IMEI: 35242204111851/4 ----------------------------- No answer from phone Error read info pls help |
08-28-2010, 12:25 | #2 (permalink) |
Banned Join Date: Sep 2008 Location: Dc-serviceteam Age: 38
Member: 857234 Status: Offline Sonork: Dc Thanks Meter: 197 | It Ask Qaulcom mode i Think . Put in Qualcom mode for unlock . Disconnect to pc . Type *#197328640# -> common -> usb config -> Qualcomm mode reconnect to pc , make Read info for check com port and choose for job . |
08-28-2010, 17:15 | #5 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
09-24-2010, 11:47 | #6 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Message of William Branham
Member: 239523 Status: Offline Thanks Meter: 210 | here is solution: go to "setting" then "personalize" then "phone setting" then "usb mode" and there select directly samsung pc studio. dont leave it on : "ask on connection". now after type *#197328640# -> common -> usb config -> Qualcomm mode. connect usb cable now and install drivers in z3x directory from B7320_B7330_Drivers folder. choose ur comport in the program and unlock ur phone. thanks |
The Following User Says Thank You to bamogil For This Useful Post: |
11-02-2010, 15:46 | #7 (permalink) |
No Life Poster Join Date: Feb 2006 Location: pakistan Age: 49
Member: 232607 Status: Offline Sonork: 100.1585040 Thanks Meter: 260 | Model: SGH-T359 CountryCode: TMB Factory SW: UVJE1 UniqueNumber: 90650001370585 MemoryPhone: K5W2G1HACF(T359)S IMEI: 35242204245216/9 Phone S/N: RPKZ885331 Build: Q6270B-KPVZL-1.5.40T Reading SysInfo... OK Calculating... error Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:01:06) Freeze code: 46268584 NET lock: #7465625*638*17595049# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.6 |
Eeprom in Samsung SGH 600 | Kaster | Hardware Equipments for GSM | 0 | 12-16-2001 12:23 |
Samsung SGH-A400 for sale | psych0 | Main Sales Section | 0 | 11-24-2001 00:01 |
Samsung sgh-2100 | Pandemonio100 | Samsung Hardware Repair | 2 | 09-04-2001 18:59 |
SAGEM SGH-200 (HELP ME ) Can you send to me eeprom from this phone ? | jonwillow | Infineon C16X M51 & ARM7 M52 BASED | 0 | 06-23-2000 09:44 |
Samsung SGH-200 (Help me -I need eeprom.) | jonwillow | Old Ericsson Phones & Sony Phones | 0 | 06-23-2000 09:38 |
