Old 03-02-2010, 18:38   #1 (permalink)
LuisinhoCell's Avatar
Member: 264903
Sonork: 1584531
Tutoring Unlock via Z3xBox
C270 / C276 - Unlock Procedure (Via Z3X-Box)
Remarks:
- Use RJ45 C450 or E210
Procedure:
- Select Model C270
- Select the COM PORT of the Box
- Click on the button DIRECT UNLOCK
- After the program show the message "Please, connect phone and press power button 3 seconds"
- Wait for the message Unlock
Old 03-02-2010, 18:57   #2 (permalink)
Member: 264903
Sonork: 1584531
Unlock J165L Video
LuisinhoCell
Old 03-02-2010, 18:59   #3 (permalink)
fypoi's Avatar
Member: 712832
good job bro, we need more good luck
The Following 9 Users Say Thank You to fypoi For This Useful Post:
Old 03-02-2010, 19:30   #4 (permalink)
Member: 264903
Sonork: 1584531
Unlock E2210L
Old 03-02-2010, 19:40   #5 (permalink)
fypoi's Avatar
Member: 712832
good good good good
The Following 7 Users Say Thank You to fypoi For This Useful Post:
Old 03-03-2010, 19:12   #6 (permalink)
Member: 264903
Sonork: 1584531
Unlock C506
select C520
Selected model: C520
Selected com port: COM93
Selected speed port: 460800
El teléfone deve estar Ligado!
Entering TestMode... OK
SW: C506VIGD5
Langpack: Not found langpack !
IMEI: 35515301393467
S/N: RS4P989805
HW-> MP 0.301
Senha do Teléfone: 00000000
Sum Flash: 1
Flash Prod ID: 0b0
Flash Device ID: 001d1111
Flash size: 16777216 Bytes
Flash sectors: 131 sectors
Bluetooth ID: BT não foi encontrado
Status OTP: OTP não presente
MSL DESACTIVADO - VERDADERO
Bloqueios está ativo
[NETLOCK]: Usar #0111*53128340# para desativar esse bloqueio
[SIMLOCK]: Usar #0141*00000000# para desativar esse bloqueio
Ler as informações - ok
Tempo Decorrido: 8 segundos, sw ver: 3.4.0030
Start unlock........
SW: C506VIGD5
NET e bloqueio do SIM - Desactivado
Alterando a senha no telefone -> 00000000
Desbloqueio - ok
Tempo Decorrido: 7 segundos, sw ver: 3.4.0030
The Following 16 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 03-04-2010, 10:18   #7 (permalink)
billa2008's Avatar
Member: 687128
how to flash procedure step by step
The Following 6 Users Say Thank You to billa2008 For This Useful Post:
Old 03-04-2010, 14:47   #8 (permalink)
Member: 264903
Sonork: 1584531
- Select Model X150 - In the "Flash Files" select the BIN files, CLA
(Note: The files are compatible to the flash module HWK)
Click Red-Info
- click "Write Firmware".
- Wait for the process and ready, device successfully updated via Z3X.
LuisinhoCell
Old 03-05-2010, 09:43   #9 (permalink)
billa2008's Avatar
Member: 687128
thank u very much
more explain flashing procedure samsung bro samsung
Old 03-05-2010, 18:25   #10 (permalink)
Member: 264903
Sonork: 1584531
writing Imei the F250
LuisinhoCell
File Type: rar Write Imei F250 LuisinhoCell.part1.rar (381.8 KB, 2267 views)
File Type: rar Write Imei F250 LuisinhoCell.part2.rar (381.8 KB, 1906 views)
Old 03-05-2010, 20:33   #11 (permalink)
Member: 1143998
A good screen, and very much hope that S5600 of the unlock screen, and let me understand the unlocking
The Following 5 Users Say Thank You to licheng For This Useful Post:
Old 03-05-2010, 20:45   #12 (permalink)
Member: 264903
Sonork: 1584531
suffice it Drive correctly recognize
Old 03-05-2010, 21:06   #13 (permalink)
tynch000's Avatar
Member: 203536
Here video for unlock s5600l with old version
http://www.4shared.com/file/14687985...80/s5600L.html
The Following 11 Users Say Thank You to tynch000 For This Useful Post:
Old 03-05-2010, 21:22   #14 (permalink)
Member: 264903
Sonork: 1584531
Unlock i321n
-select the model E530
-Clique em Unlock
Last version on support: 2G tools v3.4.0030
Selected model: E530
SW: I321NVJFL1
IMEI: 35467501016323
S/N: Ler - falhou!
HW-> MP 0.300
Sum Flash: 1
Flash Prod ID: 0b0
Flash Device ID: 000b0000
Flash size: 33554432 Bytes
Flash sectors: 259 sectors
[NETLOCK]: Usar #0111*29034125# para desativar esse bloqueio
[SIMLOCK]: Usar #0141*96692676# para desativar esse bloqueio
Tempo Decorrido: 11 segundos, sw ver: 3.4.0030
SW: I321NVJFL1
Desbloqueio - ok
LuisinhoCell
Old 03-06-2010, 06:27   #15 (permalink)
Member: 154079
brother, you wonderful.
Need more of this.Thanks
can you show us screen on how to unlock G800
The Following 4 Users Say Thank You to alolanre For This Useful Post:
Nokia 6300 Vodafone-UK SW V57.20 -> UNLOCKED VIA OPERATOR CODE VIA KEYPAD! PROOF> Mr.Ultimate Nokia Base Band 5 ( BB-5 ) 1 07-02-2009 10:11
v3r unlock via ubl and via tp good mr manole. kikikokoki Ultima Box Light 0 04-08-2009 07:40
v3r unlock via ubl via tp unlock kikikokoki Ultima Box Light 1 03-15-2009 23:00
★★★ BEST & Fastest BlackBerry Unlock VIA USB + HOT Services VIA IMEI ★★★ E_H Main Sales Section 0 12-26-2008 18:08
Page generated in 0.56856 seconds with 12 queries
