Old 03-15-2010, 18:13   #16 (permalink)
LuisinhoCell's Avatar
Member: 264903
Sonork: 1584531
Thanks Meter: 3,307
Unlock S5560
The Following 16 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 03-16-2010, 18:30   #17 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,307
Unlock C510L
Last version on support: 2G tools v3.4.0033
Selected model: C520
Selected com port: COM93
Selected speed port: 460800
El teléfone deve estar Ligado!
Please, connect phone
Entering TestMode... OK
SW: 51LBUIGE5
Langpack: Not found langpack !
IMEI: 35738201149266
S/N: RS6PA68157
HW-> MPW0.603
Senha do Teléfone: 00000000
Sum Flash: 1
Flash Prod ID: 0b0
Flash Device ID: 001d1111
Flash size: 16777216 Bytes
Flash sectors: 131 sectors
Bluetooth ID: BT não foi encontrado
Status OTP: OTP esta Ok!
MSL DESACTIVADO - VERDADERO
Bloqueios está ativo
[NETLOCK]: Usar #0111*87318211# para desativar esse bloqueio
[SIMLOCK]: Usar #0141*00000000# para desativar esse bloqueio
Ler as informações - ok
Tempo Decorrido: 11 segundos, sw ver: 3.4.0033
Start unlock........
SW: C51LBUIGE5
NET e bloqueio do SIM - Desactivado
Alterando a senha no telefone -> 00000000
Desbloqueio - ok
Tempo Decorrido: 8 segundos, sw ver: 3.4.0033
Select Model C520
Click Red Info
Click UNLOCK
The Following 6 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 04-08-2010, 14:50   #18 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,307
Unlock S5600
Select Model
Mini USB cable
Choose option (New Security)
Click UNLOCK SP
to reset the security code
Click RESET USER CODE
LuisinhoCell
The Following 11 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 04-08-2010, 19:55   #19 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,307
Unlock SofBank 709SC
LuisinhoCell
Old 04-19-2010, 17:08   #20 (permalink)
Member: 807168
Thanks Meter: 2
Tuto i8510..................
Old 04-20-2010, 07:47   #21 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 499
any body help me how to unlock i8320 .
thanks in advance
Old 04-20-2010, 17:40   #22 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,307
thanks in advance
Do as our friend did this Topic
Luisinhocell
Old 04-20-2010, 18:24   #23 (permalink)
mtony969's Avatar
Member: 24552
Thanks Meter: 12
Originally Posted by luisinhocell View Post
suffice it Drive correctly recognize
That dont work for me unable t read unique code
Old 05-08-2010, 16:48   #24 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,307
Unlock T459
[IMG]http://1.bp.********.com/_6uelXRSeyRA/SdUxT9y2zGI/AAAAAAAAKFM/Uy4G7okVaPA/s400/CelularSamsungT459Scrapy1.jpg[/IMG]
Last version on support: 2G tools v3.4.0046
Selected model: T459
Selected speed port: 921600
Please, connect phone and press power button 3 seconds
Teléfone Detectado
Use automatic parameters
Telefone em TAT MODE
Phone IMEI: 35975902076705
Phone SW: T459UIIB1_H
Phone BT ADDR: 0024-90-BE5141
Phone SN: RS5S425174
Deactivated MSL - TRUE
[FREZEE]: 44206090
[NET Lock]: 25864360
[Subset Lock]: 00000000
[SP Lock]: 00000000
[CP Lock]: 00000000
[Sim Lock]: 00000000
Tempo Decorrido: 9 segundos, sw ver: 3.4.0044
Teléfone Detectado
All Code change to -> 00000000
Desbloqueio - ok
Tempo Decorrido: 27 segundos, sw ver: 3.4.0044
LuisinhoCell
The Following 10 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 06-01-2010, 19:46   #25 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,307
READ NEWS FOR DETAILS!
Checking ports... ok
Searching Samsung USB interface... detected (COM33)
Checking mobile state... normal
Model: 920SC
SW: 920SCHC3
IMEI: 351662020837607
Searching phone at COM interface... ok
Model: 920SC
SW: 920SCHC3
Unlock as Softbank... ok
Model: 920SC
SW: 920SCHC3
Model: 920SC
SW: 920SCHC3
Model: 920SC
SW: 920SCHC3
Model: 920SC
SW: 920SCHC3
IMEI: not readable
Reseting...
Phone passwd - 9999
LuisinhoCell
Old 06-02-2010, 02:46   #26 (permalink)
Member: 770003
Thanks Meter: 2
C270 / C276 - Unlock Procedure (Via Z3X-Box)
Remarks:
- Use RJ45 C450 or E210
Procedure:
- Select Model C270
- Select the COM PORT of the Box
- Click on the button DIRECT UNLOCK
- After the program show the message "Please, connect phone and press power button 3 seconds"
- Wait for the message Unlock
calbe that you do, phone off, on, with battery, without bateris? and what is the procedure that I do with the phone?
The Following 2 Users Say Thank You to sergio ariel For This Useful Post:
Old 06-03-2010, 05:28   #27 (permalink)
sanjubhai's Avatar
Member: 386868
Thanks Meter: 124
how to reset the user code in i450 and which cable is used
thanks in advance.
sanjubhai.
The Following User Says Thank You to sanjubhai For This Useful Post:
Old 06-06-2010, 20:12   #28 (permalink)
Member: 416181
Thanks Meter: 5
Unlock samsung corby pro b5310
Please,
video on how to unlock samsung corby pro B5310,
very urgent,I am a new user of this box. Purchased it last week!
thank you in advance,
vincent
The Following User Says Thank You to vincentgo4it For This Useful Post:
Old 06-07-2010, 15:39   #29 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,307
Cable used = E210
Battery = Yes
Click Unlock and push the power by 3 Seconds
LuisinhoCell
The Following 5 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 06-07-2010, 20:20   #30 (permalink)
Member: 416181
Thanks Meter: 5
Originally Posted by vincentgo4it View Post
Please,
vincent
Please, any replay? any help?
thank you
Nokia 6300 Vodafone-UK SW V57.20 -> UNLOCKED VIA OPERATOR CODE VIA KEYPAD! PROOF> Mr.Ultimate Nokia Base Band 5 ( BB-5 ) 1 07-02-2009 10:11
v3r unlock via ubl and via tp good mr manole. kikikokoki Ultima Box Light 0 04-08-2009 07:40
v3r unlock via ubl via tp unlock kikikokoki Ultima Box Light 1 03-15-2009 23:00
★★★ BEST & Fastest BlackBerry Unlock VIA USB + HOT Services VIA IMEI ★★★ E_H Main Sales Section 0 12-26-2008 18:08
Page generated in 0.50855 seconds with 9 queries
