06-30-2014, 04:01 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: philippines
Member: 407557 Status: Offline Thanks Meter: 102 | Unable to flash and unlock SGHI747M now phone has Android 4.1.1 came from other tech I would like to reflash back to stockrom already have the firmware but cannot flash or if not possible repair IMEI so that I can unlock the phone Unable to Read,flash, repair IMEI in Z3x Unable to flash in Odin any version Unit is detected on PC but with z3x it shows this logs Selected model: I747M Selected port: COM51 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.17.4 Reinstalled driver > no go Already followed carefully steps in help (z3x) no go Cannot update through SD USB Debug Enabled. Download mode working but for some reason I can't flash Recovery mode working it can wipe and use install from SD Phone is ROOTED Current phone status >> all functioning except no signal due to IMEI problem also I wonder why suddenly a popped up message always shows on display screen HELP HElp HELP! |
06-30-2014, 08:55 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Canada
Member: 119464 Status: Offline Thanks Meter: 288 | Try to reinstall drivers...still doesn't work then it's might be usb port. BR Sent from my SM-N900W8 using Tapatalk |
The Following User Says Thank You to rasgula For This Useful Post: |
07-01-2014, 03:48 | #4 (permalink) |
Member: 119464 Status: Offline Thanks Meter: 288 | your phone is in test mode.try to use ver 16.9 to repair imei/babseband/network. regards |
