01-11-2014, 16:20 | #1 (permalink) |
Freak Poster Join Date: May 2010
Member: 1305804 Status: Offline Thanks Meter: 22 | Unfortunately, SuperSU has stopped I747m, 4.3 i can not open superSU, it says Unfortunately, SuperSU has stopped NOt abble to update from Play store i can not install UPDATE!! do you have any solution |
01-11-2014, 16:53 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Marocunlocking™
Member: 248858 Status: Offline Sonork: 100.1608346 Thanks Meter: 216 | - Mettre le mod sur la Sd Card - Démarrer en mode CWM recovery (téléphone éteint, maintenir les touches "volume haut" + "home" + "power") http://dl.xda-developers.com/attachd...CRIPT_V1.0.zip |
The Following User Says Thank You to pikiche For This Useful Post: |
01-11-2014, 16:55 | #5 (permalink) |
Member: 248858 Status: Offline Sonork: 100.1608346 Thanks Meter: 216 | 1.root the phone 2. open supersu and disable samsung KNOX when supersu asks to 3. Dial *#0808# select DM+MODEM+ADB click ok connect phone to usb 4. Click on Repair Select Repair EFS, Repair Network and Write the original Imei to the phone. 5. Phone will be Unlocked after reboot |
01-17-2014, 22:32 | #10 (permalink) |
No Life Poster Join Date: Jun 2006 Location: CANADA
Member: 292789 Status: Offline Thanks Meter: 636 | i have also same problem with S3 i747m 4.3 After rooting my I747m BELL 4.3 i can not open superSU, it says Unfortunately, SuperSU has stopped NOt able to update from Play store i can not install UPDATE from play store !! do you have any solution |
05-20-2014, 17:01 | #13 (permalink) | |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote:
i solved by go to play store and update supersu then supersu ask for disable knox and its working now | |
05-20-2014, 18:05 | #14 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Canada
Member: 119464 Status: Offline Thanks Meter: 288 | use this for root 1747M safe root - Download - 4shared - |
10-23-2014, 20:43 | #15 (permalink) |
Major Poster Join Date: Oct 2012
Member: 1822765 Status: Offline Sonork: Ugoboy Thanks Meter: 5 | I believe this works download superuser apk,install it goto settings look for reinstall superuser after uninstalling goto playstore download and update superuser |
