07-31-2017, 19:54 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: In My PC Age: 46
Member: 165971 Status: Offline Thanks Meter: 65 | unlock c701f/ds failed Code: UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-C701F Selected port: COM2 Z3X BOX Serial Port Software version: 29.0 Checking Login and Password... OK Ballance: 35 crd. Waiting ADB device... OK Reading phone info... Model: SM-C701F Android version: 6.0.1 Product code: SM-C701FNBDINS Phone version: C701FDDU1AQC7 PDA version: C701FDDU1AQCA CSC version: C701FODD1AQCA CSC country code: India CSC sales code: INS HW version: MP 0.100 Phone SN: RZ8J50T5DAP Chip name: MSM8953 Modem board: MSM8953 Security patch: 2017-04-01 RF cal date: 2017.05.15 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM70 detected Reading data from phone... OK Calculating... error (3) Exception: Invalid pointer operation Done with Samsung Tool PRO v.29.0 pb in server or c701f not supported ? |
09-27-2017, 11:35 | #3 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Uzbekistan Bukhara
Member: 300929 Status: Offline Thanks Meter: 27 | Operation: Read Codes via Server Selected model: SM-C701F Software version: 29.4 Checking Login and Password... OK Ballance: 35 crd. Waiting ADB device... OK Reading phone info... Model: SM-C701F Android version: 6.0.1 Product code: SM-C701FZDDINS Phone version: C701FDDU1AQD1 PDA version: C701FDDU1AQE2 CSC version: C701FODD1AQD1 CSC country code: India CSC sales code: INS HW version: MP 0.100 Phone SN: RZ8J40GZ4FK Chip name: MSM8953 Modem board: MSM8953 Security patch: 2017-05-01 RF cal date: 2017.04.10 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM8 detected Reading data from phone... OK Calculating... error (3) Exception: Invalid pointer operation |
11-11-2017, 15:00 | #5 (permalink) |
Freak Poster Join Date: Feb 2010 Location: sharjha
Member: 1236922 Status: Offline Sonork: sajer007 Thanks Meter: 101 | C710F error any solution Software version: 29.6 Checking Login and Password... OK Ballance: 25 crd. Waiting ADB device... OK Reading phone info... Model: SM-C701F Android version: 6.0.1 Product code: SM-C701FZDDINS Phone version: C701FDDU1AQI4 PDA version: C701FDDU1AQI4 CSC version: C701FODD1AQI4 CSC country code: India CSC sales code: INS HW version: MP 0.101 Phone SN: RZ8J92QQZMZ Chip name: MSM8953 Modem board: MSM8953 Security patch: 2017-08-01 RF cal date: 2017.09.27 IMEI: 357.......... Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM7 detected Reading data from phone... OK Calculating... error (3) Exception: Invalid pointer operation Done with Samsung Tool PRO v.29.6 |
11-15-2017, 07:20 | #8 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: Bangladesh
Member: 1845954 Status: Offline Sonork: 100.1622497 Thanks Meter: 397 | Quote:
12-01-2017, 12:28 | #12 (permalink) |
Junior Member Join Date: Jul 2008
Member: 822148 Status: Offline Thanks Meter: 1 | i have same problem how to unlock it ? UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-C701F Software version: 30.1 Checking Login and Password... OK Ballance: 31 crd. You have 31 credit(s) left. This opreratin takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-C701F Android version: 6.0.1 Product code: SM-C701FNBDINS Phone version: C701FDDU1AQI4 PDA version: C701FDDU1AQI4 CSC version: C701FODD1AQI4 CSC country code: India CSC sales code: INS HW version: MP 0.101 Phone SN: RZ8JA0V57YF Chip name: MSM8953 Modem board: MSM8953 Security patch: 2017-08-01 RF cal date: 2017.10.11 IMEI: 357169081982904 Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM15 detected Reading data from phone... OK Calculating... error (3) Done with Samsung Tool PRO v.30.1 |
12-30-2017, 17:22 | #14 (permalink) |
Junior Member Join Date: Jun 2005 Location: Ukraine, Kharkiv
Member: 154719 Status: Offline Thanks Meter: 7 | Hi, tell me please did you decide the problem? Thank you Operation: Read Codes via Server Selected model: SM-C701F Selected port: COM6 SAMSUNG Mobile USB Serial Port Software version: 30.2.2 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-C701F Android version: 6.0.1 Product code: SM-C701FZDDINS Phone version: C701FDDU1AQI4 PDA version: C701FDDU1AQI4 CSC version: C701FODD1AQI4 CSC country code: India CSC sales code: INS HW version: MP 0.101 Phone SN: RZ8J91CHZCK Chip name: MSM8953 Modem board: MSM8953 Security patch: 2017-08-01 RF cal date: 2017.09.15 IMEI: 357169081418859 Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM12 detected Reading data from phone... OK Calculating... error (3) Done with Samsung Tool PRO v.30.2.2 |
