Old 07-13-2019, 14:42   #1 (permalink)
Member: 1538832
Sonork: bassgsm
Thanks Meter: 8
unlock g900p 6.0.1 last security
help me to downgrade modem g900p 6.0.1 version g900pvps3cqd1 I tried it with the modem CP_G900FXXU1BOL3.tar.md5 but it shows fail is someone has a compatible modem version
Old 07-13-2019, 14:49   #2 (permalink)
Crazy Poster
Member: 2569608
Thanks Meter: 62
the process is simple brother
flash full g900p stock, 4 files is best
go thru setup on the phone
enable usb debugging
then on pc download this file - https://download.chainfire.eu/408/CF...pr-smg900p.zip
extract and flash this file in ODIN IN THE AP SECTION
it will take a few min to boot its ok just give it time.
after it comes on look for a new app called SUPERSU
when it first opens there will be some ad or something just hit no thanks
then click the settings in the right hand corner of supersu
click DEFAULT ACCESS
change it to GRANT
next open up z3x or octo etc, choose g900p and select domestic unlock
after unlock success flash back stock 4 files
The Following User Says Thank You to jrotc1sg For This Useful Post:
Old 07-13-2019, 15:05   #3 (permalink)
Member: 2613252
Thanks Meter: 993
Helloi, first install the binary 3 eng modem (modem combination), because probably the network lock on the Android 6.0.1 version is not supported
once the u3 modem combination is installed, root on the phone and proceed with the network lock z3x, once the network is unlocked install the stock binary 3 modem
G900PVPU3AOF1_ENG_MODEM_U3
Download :
https://boxwares.net/47ee19b9835cc52...xWares.tar.md5
The Following User Says Thank You to amleto90 For This Useful Post:
Old 07-13-2019, 16:24   #4 (permalink)
Member: 1538832
Sonork: bassgsm
Thanks Meter: 8
I flash the G900PVPU3AOF1_ENG_MODEM_U3 c ok but when I run the root ca is always fail
Old 07-13-2019, 16:34   #5 (permalink)
Member: 2613252
Thanks Meter: 993
what does it fail when you are root or with the combination modem installed and the root via z3x fails to unlock the network?
Old 07-13-2019, 16:44   #6 (permalink)
Member: 1538832
Sonork: bassgsm
Thanks Meter: 8
Download :
i flash the modem c ok i unlock the network with z3x c ok but it still displays sim card invalid Reading phone info ... Reading IMEI ... OK IMEI: 990004734097474 Unlocking ... OK Reseting ... OK Unlock done Done with Samsung Tool PRO v.36.8
Old 07-13-2019, 16:45   #7 (permalink)
Member: 1538832
Sonork: bassgsm
Thanks Meter: 8
Reading IMEI ... OK
Unlocking ... OK
Reseting ... OK
Unlock done
Old 07-13-2019, 16:48   #8 (permalink)
Member: 2613252
Thanks Meter: 993
[QUOTE=bassgsm;13734105]Reading phone info ...
Reading IMEI ... OK
Unlocking ... OK
Reseting ... OK
Unlock done
when you have installed the eng modem and unlocked the network have you tried to install the stock firmware modem to see if the network is unlocked and to insert the sim if the network works ?,
You can post the complete z3x log of the unlock operation for g900p
Old 07-13-2019, 17:02   #9 (permalink)
Member: 1538832
Sonork: bassgsm
Thanks Meter: 8
no I'm not flashing with the original modem I just flash with eng_modem then I unlock the network with z3x
Old 07-13-2019, 17:05   #10 (permalink)
Member: 2613252
Thanks Meter: 993
when you have installed the eng modem and you have unlocked the network with z3x, you should put the stock firmware modem and once you put the stock firmware modem try to insert the sim to see if the network is unlocked because the modem is the modem of the combination and with the SIM inserted the network does not work
Old 07-13-2019, 19:27   #11 (permalink)
Member: 1538832
Sonork: bassgsm
Thanks Meter: 8
thank you my brother for your help it works
The Following User Says Thank You to bassgsm For This Useful Post:
Page generated in 0.29343 seconds with 7 queries
