== Unlock i9000 step by step using Z3x == Hello guys, I just saw this very useful unlock steps, and I would share it with everybody! :p Special thanks to hackgsm! How to unlock SAMSUNG i9000 GALAXY? Steps: - download patch file from z3x server.(I9000_XXJPK_modem_patched) - 1st write patch file in phone area (select patch file as it is in ".tar" file dont extract it ) - Turn the phone off and than put it on (Download mode) (Press and hold Volume Down + Home + Power Button) http://img199.imageshack.us/img199/8582/3button.png - Than press update firmware - After flash turn on phone and turn on usb debugging (setting -> development -> usb debugging) - Finally click unlock sp - Wait than u can see net code http://i55.tinypic.com/m9svus.jpg original link: Unlock i9000 step by step using z3x Press the thanks button if it is useful for you! :D;):D |
Hi, My phone is totally dead while new software updating so its not going to downloading mode and also not getting turn on... Can you help me for that ??? |
modem patch once i downloaded the modem patch from the z3x site ,i then patched the phone ,but the phone would not go into the download mode ,so i used the special cable which puts it into download mode ,the phone would not except the patch ,but then the phone would not boot,even tried to flash the phone .Had to send the phone away for boot repair.The only thing i can think may have caused this ,was the customer updated his phone with the latest version from the samsung web site. |
very useful bro.........thx vv much i love u.....hahaha |
great! thank you very much! |
now with new update no need to flash with pacth |
Should of just used riff box to jtag it ( that would of got it working again ) Sent from my xxx using Tapatalk. |
good post ................................. |
how to write patch file in fone im totally beginner can anyone please help me thanks |
Count supported models - 223 File analysis... OK Total File Size: 0x00C00000 Searching USB flash interface... detected COM30 Opening Port... OK Setup connection... OK Reading PIT From Phone... OK Sending modem.bin... OK Done with Samsung 3G tool ver 9.4 Searching Android modem... not found Done with Samsung 3G tool ver 9.4 Searching Android modem... detected (COM29) Model: GT-I9000 CountryCode: ¿µ±¹ Factory SW: I9000BOJPB UniqueNumber: 74060002421371 MemoryPhone: KB100D00WM(I9000) Phone SW: I9000XXJPK Phone S/N: 00000000000 IMEI: 35653104013618/0 Bypass MSL... OK Reading Security... OK Calculating codes... OK (time - 00:00:00) Freeze code: 00000000 NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
phone wont go into recovery mode by pressing volume up +home+power on |
Regards |
hi my phone is i9000bvjg2 is that solution correct this phone? |
i9000b request code after unlock 1 Attachment(s) Wi did i9000b request code after unlock sucessfull with Z3x? Count supported models - 302 Searching USB Flash Interface... detected COM10 Opening Port... OK Setup connection... Error Done with Samsung Tool ver 12.2 Searching Samsung USB Modem... detected (COM10) Reading Phone Info... OK Model: GT-I9000B Country Code: ZVV Cal Date: 2011-01-06 Factory SW: VJJPD Unique Number: 78110000240455 Memory Phone: KB100D00WM(I9000) IMEI: 353940 Edited SW: I9000BVJJG8/I9000BZTOJG7/I9000XXJPK/I9000BVJJG8 Product Code: GT-I9000HKBZVV Bypass MSL... Error Done with Samsung Tool ver 12.2 Searching Samsung USB Modem... detected (COM10) Reading Phone Info... OK Model: GT-I9000B Country Code: ZVV Cal Date: 2011-01-06 Factory SW: VJJPD Unique Number: 78110000240455 Memory Phone: KB100D00WM(I9000) IMEI: 3539400 Edited SW: I9000BVJJG8/I9000BZTOJG7/I9000XXJPK/I9000BVJJG8 Product Code: GT-I9000HKBZVV Bypass MSL... OK Unlocking ... OK Done with Samsung Tool ver 12.2 Dont presents the unlock codes NCK, MCK, Freeze, etc, Unlocking... OK only, but the cell need the code PIN Unlock Network SIM yet ? :mad: |
is't after put the patch file press flash with check unlock (patch)? |
