09-01-2016, 05:13 | #1 (permalink) |
No Life Poster Join Date: Sep 2014 Location: LORD BUDDHA Birth Place,NEPAL
Member: 2257857 Status: Offline Thanks Meter: 331 | Unlock i9500 |
09-01-2016, 05:26 | #3 (permalink) |
Member: 2257857 Status: Offline Thanks Meter: 331 | Here login UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: GT-I9500 Software version: 20.5 Waiting ADB device... Phone not found Done with Samsung Tool v.20.5 |
09-01-2016, 06:55 | #4 (permalink) |
Member: 2257857 Status: Offline Thanks Meter: 331 | Selected model: I9500 Selected port: COM89 Z3X BOX Serial Port Selected port speed: 115200 Phone not found Done with Samsung Tool v.17.0 Selected model: I9500 Selected port: COM89 Z3X BOX Serial Port Selected port speed: 115200 Phone not found Done with Samsung Tool v.17.0 Selected model: I9500 Selected port: COM89 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.17.0 Selected model: I9500 Selected port: COM89 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM530 Reading phone info... Software version: =1,1 IMEI: 004999010640000 Done with Samsung Tool v.17.0 Selected model: I9500 Selected port: COM89 Z3X BOX Serial Port Selected port speed: 115200 Phone not found Done with Samsung Tool v.17.0 Selected model: I9500 Selected port: COM89 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.17.0 Selected model: I9500 Selected port: COM89 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM530 Reading phone info... Software version: =1,1 IMEI: 004999010640000 Done with Samsung Tool v.17.0 Selected model: I9500 Selected port: COM89 Z3X BOX Serial Port Selected port speed: 115200 Phone not found Done with Samsung Tool v.17.0 Selected model: I9500 Selected port: COM89 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.17.0 Selected model: I9500 Selected port: COM89 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM530 Reading phone info... Software version: =1,1 IMEI: 004999010640000 Done with Samsung Tool v.17.0 Selected model: I9500 Selected port: COM89 Z3X BOX Serial Port Selected port speed: 115200 Phone not found Done with Samsung Tool v.17.0 |
09-02-2016, 05:44 | #9 (permalink) |
Insane Poster Join Date: Sep 2014 Location: Venezuela Age: 29
Member: 2262368 Status: Offline Thanks Meter: 57 | Do repair imei with a certificate write!! in samsung tool 26.6 tab BACKUP. just make sure that the phone is rooted i can give you a cert if you don't have |
