11-27-2013, 03:48 | #1 (permalink) |
Freak Poster Join Date: Jun 2010
Member: 1318873 Status: Offline Thanks Meter: 18 | unlock i9505 4.2.2 without *#7284# 1.first search and flash this file with odin 3.0.7 *I9505_File_for_Unlock_4.2.2* if you face any error during flash juste delete .md5 in the end of line. 2. tap in phone keyboard *#0808# - DM - MODEM - ADB 3. *#9090# - DM OVER UART[*] reboot automatically 4. Connect Phone Z3X Box And Wait install Driver (USB CABLE) 5. select *samsung mobile usb serial port* in com port if not found check latest kies for drivers 6.press unlock and its done her is the log Selected model: I9505 Selected port: COM14 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.16.2 Selected model: I9505 Selected port: COM14 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Searching server... OK NET lock: #7465625*638*17593753# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.16.2 press thanks if i help you |
The Following 6 Users Say Thank You to jalal1231986 For This Useful Post: |
12-02-2013, 14:01 | #2 (permalink) |
Insane Poster Join Date: Dec 2006 Location: pakistan
Member: 408299 Status: Offline Thanks Meter: 1 | Selected model: I9505 Selected port: COM14 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.16.2 Selected model: I9505 Selected port: COM27 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.16.2 Selected model: I9505 Selected port: COM28 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.16.2 Selected model: I9505 Selected port: COM14 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.16.2 Selected model: I9505 Selected port: COM14 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Done with Samsung Tool v.16.2 Selected model: I9505 Selected port: COM14 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... error access denied Done with Samsung Tool v.16.2 Selected model: I9505 Selected port: COM14 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... error access denied Done with Samsung Tool v.16.2 Selected model: I9505 Selected port: COM14 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... error access denied Done with Samsung Tool v.16.2 Done with Samsung Tool v.16.2 |
12-02-2013, 17:42 | #3 (permalink) |
Temporary banned !! Join Date: Sep 2004
Member: 83645 Status: Offline Thanks Meter: 111 | Or maybe like this one... Selected model: I9505 Selected port: COM11 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 No answer from phone Done with Samsung Tool v.15.3 Selected model: I9505 Selected port: COM11 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Port open fail COM11 Done with Samsung Tool v.15.3 Selected model: I9505 Selected port: COM18 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Searching server... OK NET lock: #7465625*638*2litsGSM# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.15.3 Connect phone via diagnostic mode. Install drivers. Read Codes in Z3X. br, |
01-09-2014, 03:16 | #5 (permalink) | |
Member: 1318873 Status: Offline Thanks Meter: 18 | Quote:
01-10-2014, 19:00 | #6 (permalink) |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | downgrade modem part only and then unlock read this do it own risk ( that is what I did ) http://forum.gsmhosting.com/vbb/f453...34/index2.html Last edited by kariakala; 01-10-2014 at 19:09. |
03-16-2014, 07:32 | #8 (permalink) |
Freak Poster Join Date: May 2009 Location: Bangladesh
Member: 1024699 Status: Offline Sonork: 100.1622959 Thanks Meter: 599 | I9505 4.2.2 Read Code Done Using Usb Cable........ 1.Flash this file on PDA with odin 3.0.7 I9505_File_for_Unlock_4.2.2 - Download - 4shared Any error during flash juste delete .md5 in the end of line. (Thanks jalal1231986)I am only shere unlock file & successfull report....... |
