Unlock I9505 only with usb cable and z3x box you need to put phone in this mode: *#7284# UART: *modem pda USB: modem *pda Qualcoom setiings: MTP MTP ADB PTP PTP ADB RNDIS DM MODEM RMNET DM MODEM *DM MODEM ADB *#9090# *1 dm dun over hs usb 2 dm dun over hsic 3dmdun rmnet over hsusb 4dm over uart 5dbg msg on 6dbg msg off *#0808# *cp ap mtp mtp+adb ptp ptp+adb rndis+dm+modem rmnet+dm+modem *dm+modem+adb 1. Goto SETTINGS 2. Click ABOUT DEVICE 3. Trap 7 Times on the BUILD NUMBER. Once done you should get a message stating "You Are Now A Developer" Once you have seen the message you can then go back to settings and you should have the option "Developer Options", now you can enable USB Debugging. log on box: [21:23:38] LaB. Phones: Selected model: I9505 Selected port: COM21 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Searching server... OK NET lock: #7465625*638*39515027# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.14.4 |
Unfortunately in 4.2.2 it does not work. Any new workaround? |
downgrade, and made unlock:) |
how to downgrade man? i can't find version,only 4.2.2 pls say me were find her? |
sir i have same problem when i type *#7284# did not show urt modem,, |
you should downgrde for fisrts release of android version 4.2.2. |
I have same problem too, nathing whem *#7284# |
DOWNGRADE NEEDED FOR SURE You need to put phone in this mode: *#7284# UART: *modem USB: *pda Qualcoom setiings: *DM MODEM ADB *#9090# *4dm over uart *#0808# ap *dm+modem+adb 1. Goto SETTINGS 2. Click ABOUT DEVICE 3. Trap 7 Times on the BUILD NUMBER. Once done you should get a message stating "You Are Now A Developer" once you have seen the message you can then go back to settings and you should have the option "Developer Options", now you can enable USB Debugging. Selected model: I9505 Selected port: COM48 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.14.9 CHECK ALL TIME *#9090# IF dm over uart |
i9505 unlock done Selected model: I9505 Selected port: COM21 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Done with Samsung Tool v.14.9 Selected model: I9505 Selected port: COM21 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.14.9 |
just dial *#7284# select modem use uart cable and press unlock Selected model: I9505 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done |
1. Phone must be powered on. 2. Type *#0808# and select "DM + MODEM + ADB". 3. Choose correct com-port in Port settings. 4. Connect the phone to PC via micro-USB cable. 5. Press "Unlock" button. Selected model: I9505 Selected port: COM48 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Done with Samsung Tool v.14.8 Selected model: I9505 Selected port: COM48 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.14.8 |
[QUOTE=DUSKnenixs;9421528]you need to put phone in this mode: ... *#0808# *cp ap mtp mtp+adb ptp ptp+adb rndis+dm+modem rmnet+dm+modem *dm+modem+adb ... In my device if I selece "cp" disapear the next options. *cp or *ap?? |
1. Phone must be powered on. 2. Type *#0808# and select "DM + MODEM + ADB". 3. Choose correct com-port in Port settings. 4. Connect the phone to PC via micro-USB cable. 5. Press "Unlock" button. Selected model: I9505 Selected port: COM48 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Done with Samsung Tool v.14.8 Selected model: I9505 Selected port: COM48 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.14.9 |
