08-27-2016, 08:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Worldwide
Member: 2174901 Status: Offline Sonork: 100.1671257 Thanks Meter: 1,248 | Unlock N910T 6.0.1 You cant unlock or write cert for that we have solution Freeee Download this modem From here flash it by odin (CP) PASS : halabtech after flash make unlock or write cert if you ask about sim lock 00000000 logo : Reading phone info... Reading IMEI... OK IMEI: 35459XXXXXXXXXXX Unlocking... OK Reseting... OK Unlock done We Have Clean And Private Cert if You want We HalabTech |
The Following 2 Users Say Thank You to hosam kashto For This Useful Post: |
06-28-2019, 07:21 | #3 (permalink) |
Junior Member Join Date: Dec 2008 Location: india
Member: 921859 Status: Offline Sonork: telecare Thanks Meter: 5 | Welcome to Octoplus Box Samsung software version 2.8.0 ----------------------------------------------------------------------------------- To connect SM-N910T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. Selected firmware file: n910t_modem_for_unlock.oct Please put the phone into Download Mode and connect USB cable. To put SM-N910T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed. Performed by 2.8.0 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM64 Selected model: SM-N910T Operation: Unlock Reading info... Mode: Normal Firmware compiled date: Mar 18 2015 Firmware compiled time: 19:00:00 Firmware released date: Apr 17 2015 Firmware released time: 14:11:17 SW Version: MPSS.DI.3.0.c5-00396-M9625TAARANSZM-2 Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.8.0 Software version. |
