Old 04-10-2018, 21:17   #31 (permalink)
boliargsm's Avatar
Member: 884906
Sonork: none
Thanks Meter: 58
it works like a charm thanks guys
regards
Old 04-10-2018, 23:21   #32 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 39
regards
Post logs please! We need to know details of your phone.....
Old 04-11-2018, 09:13   #33 (permalink)
Member: 2736710
Originally Posted by imeiking View Post
i just tested on j727p unlock work and after two factory reset still there please keep in mind it is factory thru settings i did not test recovery or odin stock flash
My friend. How to do it. Instructions please?
Old 04-13-2018, 18:17   #34 (permalink)
Member: 2510340
friends the spc I read it with gcpro perfectly
Old 04-13-2018, 18:44   #35 (permalink)
Member: 2510340
by the way the solution works perfect tested from Cuba
Old 04-14-2018, 00:01   #36 (permalink)
Member: 2638112
Thanks Meter: 2
can you explain the steps.
I enabled diag using z3x and octo, but still no help with getting the msl code. do i need to root it??
Old 04-14-2018, 01:36   #37 (permalink)
Member: 2763405
Originally Posted by gsm_service4u View Post
The NV Writer needs correct MSL to write NV file
NOTE DO NOT WRITE NV FILE AS NV DATA like with z3x/gc/other tool
ITS NOT THE SAME YOU WILL REKT YOUR PHONE
only use NV WRITER BY CDMAWARE!
Where u enter MsL code in nv reader because I don’t see any MsL option.
Thanks.
Old 04-14-2018, 02:28   #38 (permalink)
Faheem Anjum's Avatar
Member: 399832
Thanks Meter: 23,679
Thanks.
You need spc code not msl
Old 04-14-2018, 07:08   #39 (permalink)
Member: 2627990
Thanks Meter: 4
Here I found everything step by step!!
BOOM!!! j327p BIT 3 Unlock(Liberación) Samsung J3 Emerge (QJ3 o QL3) Con Z3x Box o Op
There's a video on YouTube in the tread above.
Old 04-14-2018, 20:30   #40 (permalink)
Member: 2679800
CONFIRMED! After flashing full firmware with ODIN SIM Unlock still working.
Tested by me.
Thanks!!! now its time to root to not get updates from samsung anymore.
Old 04-14-2018, 20:51   #41 (permalink)
Member: 558861
Thanks Meter: 17
simple read on cdma nv writer send spc than write nv file
people use to flash cdma phones they know very well how to use cdma workshop
Old 04-14-2018, 22:03   #42 (permalink)
Member: 2510340
no, do not need root
Old 04-16-2018, 20:17   #43 (permalink)
Member: 2696553
use 7zip to use the file
Old 04-17-2018, 07:31   #44 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
Thanks Meter: 3,786
am getting
Writing NV-items from a file:
Unsuccessfully written NV-items:
50155 (0xC3EB) - Access denied
Done.
Page generated in 0.16615 seconds with 7 queries
