02-18-2016, 12:04 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Classified
Member: 1280253 Status: Offline Thanks Meter: 142 | Unlock Problem of i9505 with Z3x Its the 3rd phone samsung i9505 which now has the same problem of not reading the SIM card after unlocking with z3x ... this is not the first phone i have unlocked with z3x however i dont understand where the problem is ... the unlocking process goes normally very well however after the unlock the phone does not detect any other SIM card execpt for the original SIM card operator it is blocked to ... the phone is also NOT BLACKLISTED since the customer has the proof of purchase with him ... can anyone tell me what is going on with i9505 and z3x ???? pls help urgently br |
02-18-2016, 15:54 | #3 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Spain
Member: 840762 Status: Offline Thanks Meter: 166 | You have imei after unlock? You have damaged baseband? (show info with *#1234#) You try backup certificate and repair? You use latest version of z3x samsung tool pro? Post logs for help... BR |
02-18-2016, 17:17 | #4 (permalink) | |
Member: 1280253 Status: Offline Thanks Meter: 142 | Quote:
my friend it only works with the Original Carrier SIM and all other cards are not even detected the phone says NO SIM card everytime any suggestions ??? br | |
02-18-2016, 22:46 | #5 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
09-28-2016, 13:31 | #7 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 331337 Status: Offline Thanks Meter: 72 | I9505 after unlock this phone sim not detecting. UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: GT-I9505 Selected port: COM164 SAMSUNG Mobile USB Serial Port Software version: 26.8 Reading phone info... Reading IMEI... OK IMEI: 356843053699446 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.8 PHONE WORKING FINE BEFORE UNLOCK AND WHEN I TRIED ANOTHER NETWORK SIM IN IT IT WAS ASKING FOR UNLOCK CODE. NOW AFTER I UNLOCK PHONE ON Z3X AND WHEN I PUT SIM IN IT IT SAYS NO SIM. THIS IS MY 2ND PHONE IN 2 DAYS TIMES DID THE SAME PROBLEM. CUSTOMER IS NOT HEPPY AND ASKING FOR MORE MONEY FOR DAMAGING THERE PHONES. NEED SOLUTION ASAP PLEASE. please helppppp |
09-28-2016, 14:20 | #9 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 52
Member: 85182 Status: Offline Sonork: 1593854 Thanks Meter: 42 | UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: GT-I9505 Selected port: COM15 SAMSUNG Mobile USB Serial Port Software version: 26.8 Reading phone info... Reading IMEI... OK IMEI: 357634052781999 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.8 |
09-29-2016, 12:13 | #13 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Salford
Member: 125401 Status: Offline Thanks Meter: 22 | I don't think this is a z3x problem have a customer with a Network Unlock code input the code after it asked for unlock code with non standard sim... Input code handset rebooted... NOW dosen't recognise sim apart from Original Sim... :/ |
