05-17-2012, 18:58 | #1 (permalink) |
No Life Poster Join Date: Mar 2006
Member: 240043 Status: Offline Thanks Meter: 78 | Unlock s5830m when digit *#7284# saysme: right hard key: back Please use the menu key when digit *#9090# no make anithing action when try with digit *#197328640# -> 9 -> 4 -> usb diag only show 5 options, and in common not show usb option try with samsung 3g tool v9.4 select s5830 model and show this Enable to open COM49 Done with Samsung 3G tool ver 9.4 ----------------------------- Enable to open COM53 Done with Samsung 3G tool ver 9.4 ----------------------------- IMEI: 00000000000000/0 Reading Security... read error at: 01730000 Done with Samsung 3G tool ver 9.4 |
05-19-2012, 08:00 | #3 (permalink) |
Member: 240043 Status: Offline Thanks Meter: 78 | you are very smart, can you review first : when try with digit *#197328640# -> 9 -> 4 -> usb diag only show 5 options, and in common not show usb option this is the reason the software cant read the phone how modem and the imei is 000000000000000 you know how put the phone in usb diag? |
08-08-2012, 10:21 | #6 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Germany
Member: 753732 Status: Offline Thanks Meter: 252 | how to unlock samsung s5830m ? i have rooted phone with universal_gb_root_v20.zip http://forum.gsmhosting.com/vbb/f453...-more-1485169/ select s5830i on Z3x tool and unlock, but phone is stil locked if i enter nck: NET lock: #7465625*638*80808030# nothing happening what can i do? if i insert simcard it comes , newtork locked and Dismiss, but no entering nck... Code: Done with Samsung Tool ver 12.7 Android Version: 2.3.6 Model: GT-S5830M Product Code: GT-S5830OKUTCE Phone Version: S5830MWHLB1 PDA Version: S5830MUMLB1 CSC Version: S5830MTCELB1 IMEI: 359971045624250 Checking ROOT... TRUE Reading Data From Phone... OK Unlocking... OK Rebooting Phone... OK Done with Samsung Tool ver 12.7 Android Version: 2.3.6 Model: GT-S5830M Product Code: GT-S5830OKUTCE Phone Version: S5830MWHLB1 PDA Version: S5830MUMLB1 CSC Version: S5830MTCELB1 IMEI: 359971045624250 Checking ROOT... TRUE Reading Data From Phone... OK Please Wait, Calculating Codes... OK (time - 00:00:12) Freeze code: 00100030 NET lock: #7465625*638*80808030# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# For check lock status: *#7465625# Last edited by powerplay83; 08-08-2012 at 10:27. |
08-08-2012, 10:38 | #7 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | When you put wrong simcard and phone offers you to dismiss, try to enter freeze code directly. try to reset your phone also *2767*3855# |
08-08-2012, 10:58 | #8 (permalink) | |
Member: 753732 Status: Offline Thanks Meter: 252 | Quote:
if i check lock status , *#7465625# all locks are off. resetting phone not hleps *2767*3855# | |
08-21-2012, 17:00 | #9 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1800454 Status: Offline Thanks Meter: 0 | Same thing happens to me, iv'e selected S5830i and I direct unlocked it and readed codes but nothing happens. Also if check lock status all locks are off and when I try to change the network mode the phone asks me to insert sim card when sim card is already and pin code entered. Here is log: Searching Samsung USB Modem... Detected (COM29) Model: GT-S5830i SW: BCM21553_Modem_SI1220.2_V2.4 IMEI: 359971047945315 Done with Samsung Tool ver 12.7 Android Version: 2.3.6 Model: GT-S5830M Product Code: GT-S5830PPUTCE Phone Version: S5830MWHLB1 PDA Version: S5830MUMLB1 CSC Version: S5830MTCELB1 IMEI: 359971047945315 Checking ROOT... TRUE Reading Data From Phone... OK Please Wait, Calculating Codes... OK (time - 00:00:09) Freeze code: 20401090 NET lock: #7465625*638*10203020# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# For check lock status: *#7465625# Done with Samsung Tool ver 12.7 Android Version: 2.3.6 Model: GT-S5830M Product Code: GT-S5830PPUTCE Phone Version: S5830MWHLB1 PDA Version: S5830MUMLB1 CSC Version: S5830MTCELB1 IMEI: 359971047945315 Checking ROOT... TRUE Reading Data From Phone... OK Unlocking... OK Rebooting Phone... OK Done with Samsung Tool ver 12.7 Solution bros? Thanks. |
09-07-2012, 07:19 | #10 (permalink) |
Member: 240043 Status: Offline Thanks Meter: 78 | Fixed finally the solution is unlock with another tool , i not sure if maybe i received infraction if says setool can do it. sorry moderator but my z3x never can unlock this model |
09-10-2012, 16:03 | #11 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Lima - Peru
Member: 1168095 Status: Offline Sonork: 100.1602891 Thanks Meter: 13 | Done with Samsung Tool ver 12.7 Searching Samsung USB Modem... Detected (COM12) Model: GT-S5830i SW: BCM21553_Modem_SI1220.2_V2.4 IMEI: 359971044599065 Done with Samsung Tool ver 12.7 Android Version: 2.3.6 Model: GT-S5830M Product Code: GT-S5830OKUPET Phone Version: S5830MWHLB2 PDA Version: S5830MWHLB4 CSC Version: S5830MPETLB1 IMEI: 359971044599065 Checking ROOT... TRUE Reading Data From Phone... OK Please Wait, Calculating Codes... OK (time - 00:00:02) Freeze code: 00101020 NET lock: #7465625*638*00705040# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# For check lock status: *#7465625# Done with Samsung Tool ver 12.7 Android Version: 2.3.6 Model: GT-S5830M Product Code: GT-S5830OKUPET Phone Version: S5830MWHLB2 PDA Version: S5830MWHLB4 CSC Version: S5830MPETLB1 IMEI: 359971044599065 Checking ROOT... TRUE Reading Data From Phone... OK Repairing IMEI... OK New IMEI: 350550481708782 Rebooting Phone... OK Done with Samsung Tool ver 12.7 |
12-07-2012, 20:15 | #12 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | Quote:
3:02:15 PM - Starting ADB Server 3:02:17 PM - ADB Device: GT-S5830M 3:02:17 PM - SW Version: S5830MWHLB2 (Android: 2.3.6) 3:02:17 PM - Phone Imei: 353926051364122 3:02:17 PM - Checking SU Root Access.. 3:02:20 PM - ROOT Access: True (SuperUser) 3:02:28 PM - FS Read OK, Clearing Simlocks.. 3:02:31 PM - Unlock Done.. -- Operation done in 17 seconds -- | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
