-   Z3X-Team Products (http://forum.gsmhosting.com/vbb/f453/)
-   -   Unlock samsung A687 done with Z3x (http://forum.gsmhosting.com/vbb/f453/unlock-samsung-a687-done-z3x-1121346/)
dtdd_ansuong 10-21-2010 02:19
1. Select A797 model
2. Press 1 + 0 key and connect usb cable
3. Press Unlock SP
Tested by me
http://img684.imageshack.us/img684/614/a687.jpg
shahzad2010 10-21-2010 06:56
nice share Thanksssssssssss
jainmunda 10-21-2010 12:48
for me its not working
Press 1 + message key and connect phone by cable
Waiting for SE USB Device... OK
Detected:\\?\usb#vid_0bdb&pid_100e#5&27c6d30a&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
No answer
Done with Samsung 3G tool ver 8.6
Waiting for SE USB Device... not found
Opening Port... OK
No answer
Opening Port... OK
No answer
Opening Port... OK
No answer
vascof1 10-21-2010 13:34
where to find tool 8.6 , tool 8.5 doesnt work for me
br
jainmunda 10-21-2010 13:54
http://forum.gsmhosting.com/vbb/f453...-a797-1120051/
check in this thread
vermsky 10-27-2010 23:33
Opening Port... OK
No answer
Opening Port... OK
No answer
Opening Port... OK
No answer
Opening Port... OK
No answer
I get the same no answer error as well.
enzawigroup 10-29-2010 23:06
big and big and big thaaaaaaaaaaaaaaaaaaaaanx
done with your info
enzawigroup 10-29-2010 23:07
Count supported models - 214
Detected:\\?\usb#vid_0bdb&pid_100e#5&2c1bfe1e&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID:D900
Protocol:0401
Sending Loader 1... OK
Sending Loader 2... OK
Sending Loader 3... OK
Sending Loader 4... OK
Reading Data... OK
Calculating stage 1... OK
Calculating stage 2... OK
Calculating codes... OK (time - 00:00:45)
Freeze code: 57590962
NET lock: #7465625*638*41484048#
Sub lock: #7465625*782*00000000#
SP lock: #7465625*77*00000000#
CP lock: #7465625*27*00000000#
For check lock status: *#7465625#
bebo30 11-01-2010 18:34
thank you very good job
Gsmpower_team 11-02-2010 14:00
Opening Port... OK
No answer
Opening Port... OK
No answer
Opening Port... OK
No answer
Opening Port... OK
No answer
Contact With Me. . . .
bijaylama 11-02-2010 14:58
a687 unlock done
Detected:\\?\usb#vid_0bdb&pid_100e#6&dcfc7eb&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID:D900
Protocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:00:34)
Freeze code: 83527307
NET lock: #7465625*638*92648461#
use USB_Driver_EMP
Power OFF phone
Press and hold both keys ( 1 and message key )
Press Unlock
Connect USB cable
Papa Sol 11-19-2010 13:40
Is this really tested. I am unlocking Samsung A687 locked in AT&T. I tried all the procedure but the result is below:
Opening Port... OK
No answer
Please confirm......
alex24 11-22-2010 05:36
ayuda con el desbloqueo del a687
me gustaria saver cual es esa tecla de mensage del a687 que me dice la z3x porfavor subir una imagen
perfect1 11-22-2010 07:51
very good job brother
nice post
br
lokesh
HMtechnology 11-29-2010 12:31
3. Press Unlock SP
Tested by me
where to download this drivers software download drivers
Page generated in 0.31711 seconds with 5 queries
