samsung A687 Amigo te apoyo en esto, yo le batalle el resto, pero al fin salio, presionas el 1 mas el cero le conectas el cable usb y listo, pero sin la pila, segui los pasos de todos los post y nada, con otra maquina, algunos dicen,"sin pila" fue como me salio, suerte. Quote:
cant unlock a687 by at&t with z3x Count supported models - 214 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.6 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&8a0e485&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.6 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#6&1452302f&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer |
FOR ME ALSO SAME PROBLEM Count supported models - 217 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&5d02db7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&5d02db7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&5d02db7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&5d02db7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&5d02db7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.8 |
someone solved this issue im having no answer to need help |
Can some one plz upload the driver here for this phone..........? |
Count supported models - 217 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&15f3d041&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID:D900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:48) Freeze code: 20248363 NET lock: #7465625*638*58285051# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.8 |
tested 1000% Count supported models - 223 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&94ae1cb&0&3#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID:D900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:41) Freeze code: 58184924 NET lock: #7465625*638*92826158# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 greetings infanteria |
Me podrias decir que drivers utilizaste? |
Download Draivers samsung Full Driver.rar from Sendspace.com - send big files the easy way grettings infanteria |
1. Select A797 model 2. Press 1 + 0 key and connect usb cable 3. Press Unlock SP Tested by me Count supported models - 223 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&2eea3905&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID:D900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:26) Freeze code: 57306842 NET lock: #7465625*638*15393850# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 thanks!!!!!!!!! it's really works 100%:):):) |
thx bro i unlock toooo.. logs.. Count supported models - 214 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.6 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.6 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 8.6 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 8.6 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&3a26cb6&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID:D900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:01:08) Freeze code: 93928031 NET lock: #7465625*638*05907393# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.6 |
im gonna order this box today because i have seen z3x tool has more new models... gonna put away my NsPro for a bit! |
with several trials i finaly made it: Count supported models - 223 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Select COM port Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Select COM port Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&340a0f05&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... Error Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&340a0f05&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID:D900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:01:06) Freeze code: 91371581 NET lock: #7465625*638*26286208# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
Trancks info.......... good |
