Old 11-30-2010, 02:49   #16 (permalink)
Member: 1081345
Thanks Meter: 2
samsung A687
Amigo te apoyo en esto, yo le batalle el resto, pero al fin salio, presionas el 1 mas el cero le conectas el cable usb y listo, pero sin la pila, segui los pasos de todos los post y nada, con otra maquina, algunos dicen,"sin pila" fue como me salio, suerte.
Originally Posted by alex24 View Post
me gustaria saver cual es esa tecla de mensage del a687 que me dice la z3x porfavor subir una imagen
The Following User Says Thank You to efrains94 For This Useful Post:
Old 12-04-2010, 13:22   #17 (permalink)
Member: 874313
Sonork: polocell
Thanks Meter: 29
cant unlock a687 by at&t with z3x
Count supported models - 214
Press 1 + message key and connect phone by cable
Waiting for SE USB Device... not found
Done with Samsung 3G tool ver 8.6
Waiting for SE USB Device... OK
Detected:\\?\usb#vid_0bdb&pid_100e#5&8a0e485&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
No answer
Detected:\\?\usb#vid_0bdb&pid_100e#6&1452302f&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
No answer
Old 12-04-2010, 15:31   #18 (permalink)
Member: 149154
Sonork: 1605086.100
Thanks Meter: 37
FOR ME ALSO SAME PROBLEM
Count supported models - 217
Press 1 + 0 and connect phone by cable
Detected:\\?\usb#vid_0bdb&pid_100e#5&5d02db7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
No answer
Done with Samsung 3G tool ver 8.8
Opening Port... OK
No answer
Opening Port... OK
No answer
Opening Port... OK
No answer
Opening Port... OK
No answer
Old 12-28-2010, 01:09   #19 (permalink)
Member: 589157
Thanks Meter: 18
someone solved this issue im having no answer to need help
Old 01-06-2011, 15:13   #20 (permalink)
Member: 902377
Thanks Meter: 55
Can some one plz upload the driver here for this phone..........?
Old 01-27-2011, 11:31   #21 (permalink)
Member: 861665
Thanks Meter: 9
Detected:\\?\usb#vid_0bdb&pid_100e#5&15f3d041&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID900
Protocol:0401
Sending Loader 1... OK
Sending Loader 2... OK
Sending Loader 3... OK
Sending Loader 4... OK
Reading Data... OK
Calculating stage 1... OK
Calculating stage 2... OK
Calculating codes... OK (time - 00:00:48)
Freeze code: 20248363
NET lock: #7465625*638*58285051#
Sub lock: #7465625*782*00000000#
SP lock: #7465625*77*00000000#
CP lock: #7465625*27*00000000#
For check lock status: *#7465625#
Old 02-18-2011, 23:11   #22 (permalink)
Registered User
Member: 911276
Sonork: INFANTERIA
Thanks Meter: 16
tested 1000%
Count supported models - 223
Detected:\\?\usb#vid_0bdb&pid_100e#5&94ae1cb&0&3#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID900
Protocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:00:41)
Freeze code: 58184924
NET lock: #7465625*638*92826158#
Done with Samsung 3G tool ver 9.4
greetings
infanteria
Old 02-20-2011, 18:25   #23 (permalink)
Member: 296238
Thanks Meter: 21
Me podrias decir que drivers utilizaste?
Old 02-21-2011, 13:41   #24 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 262
Originally Posted by dtdd_ansuong View Post
1. Select A797 model
2. Press 1 + 0 key and connect usb cable
3. Press Unlock SP
Tested by me
when a796 (at&t) supported for unlock it is similar to samsung a797
Old 02-21-2011, 16:12   #25 (permalink)
Registered User
Member: 911276
Sonork: INFANTERIA
Thanks Meter: 16
Arrow
Download Draivers samsung Full Driver.rar from Sendspace.com - send big files the easy way
grettings
infanteria
Old 05-10-2011, 11:13   #26 (permalink)
Member: 991791
Thanks Meter: 14
3. Press Unlock SP
Tested by me
Detected:\\?\usb#vid_0bdb&pid_100e#5&2eea3905&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID900
Protocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:00:26)
Freeze code: 57306842
NET lock: #7465625*638*15393850#
thanks!!!!!!!!! it's really works 100%
Old 08-11-2011, 17:07   #27 (permalink)
louisgsm's Avatar
Member: 605126
Sonork: 100.1617907
Thanks Meter: 274
thx bro i unlock toooo..
logs..
Searching Samsung USB interface... not found
No answer from phone
Detected:\\?\usb#vid_0bdb&pid_100e#5&3a26cb6&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID900
Protocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:01:08)
Freeze code: 93928031
NET lock: #7465625*638*05907393#
Old 08-17-2011, 20:46   #28 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 712
im gonna order this box today because i have seen z3x tool has more new models... gonna put away my NsPro for a bit!
Old 08-19-2011, 17:34   #29 (permalink)
Member: 320120
Thanks Meter: 82
with several trials i finaly made it:
Select COM port
Select COM port
Detected:\\?\usb#vid_0bdb&pid_100e#5&340a0f05&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... Error
Opening Port... OK
Flash ID900
Protocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:01:06)
Freeze code: 91371581
NET lock: #7465625*638*26286208#
Old 08-19-2011, 17:38   #30 (permalink)
Member: 1638459
Trancks info..........
good
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.23174 seconds with 8 queries
