Old 08-25-2011, 15:23   #31 (permalink)
Member: 320120
Thanks Meter: 82
ount supported models - 223
Press 1 + 0 and connect phone by cable
Waiting for SE USB Device... not found
Done with Samsung 3G tool ver 9.4
Waiting for SE USB Device... OK
Detected:\\?\usb#vid_0bdb&pid_100e#5&2eea3905&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID900
Protocol:0401
Sending Loader 1... OK
Sending Loader 2... OK
Sending Loader 3... OK
Sending Loader 4... OK
Reading Data... OK
Calculating stage 1... OK
Calculating stage 2... OK
Calculating codes... OK (time - 00:00:54)
Freeze code: 74208502
NET lock: #7465625*638*39680379#
Sub lock: #7465625*782*00000000#
SP lock: #7465625*77*00000000#
CP lock: #7465625*27*00000000#
For check lock status: *#7465625#
Old 08-30-2011, 11:27   #32 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 302
Detected:\\?\usb#vid_0bdb&pid_100e#6&14b4c0a5&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID900
Protocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:01:00)
Freeze code: 84962058
NET lock: #7465625*638*73959517#
Old 09-01-2011, 01:33   #33 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 712
Here is my Log!!
No answer from phone
Searching Samsung USB interface... not found
Press 1 + message key and connect phone by cable
Detected:\\?\usb#vid_0bdb&pid_100e#7&1e82c7b9&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID900
Protocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:00:51)
Freeze code: 64139426
NET lock: #7465625*638*24740308#
Old 10-03-2011, 09:56   #34 (permalink)
shadigsm's Avatar
Member: 280342
Thanks Meter: 68
otocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:00:58)
Freeze code: 70253571
NET lock: #7465625*638*79028614#
Old 10-26-2011, 18:04   #35 (permalink)
Denva's Avatar
Member: 1274304
Sonork: 100.1617965
Thanks Meter: 184
Select COM port
Detected:\\?\usb#vid_0bdb&pid_100e#5&ea588c7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID900
Protocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:00:22)
Freeze code: 04147579
NET lock: #7465625*638*28029051#
Old 11-02-2011, 03:15   #36 (permalink)
descarado's Avatar
Member: 774392
Thanks Meter: 17
for me work key "1" + KEY "SYM"
Press 1 + 0 and connect phone by cable<<==== NO WORK FOR ME
Detected:\\?\usb#vid_0bdb&pid_100e#5&8a0e485&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID900
Protocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:00:32)
Freeze code: 16085958
NET lock: #7465625*638*41914736#
Old 11-30-2011, 18:13   #37 (permalink)
Member: 168512
Count supported models - 223
Detected:\\?\usb#vid_0bdb&pid_100e#5&29c7aec0&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
No answer
Opening Port... OK
No answer
Opening Port... OK
No answer
Opening Port... OK
No answer
plz can someone help me the above is what i keep getting nomatter what i do.wht next should io do plz
Old 11-30-2011, 18:15   #38 (permalink)
descarado's Avatar
Member: 774392
Thanks Meter: 17
Re instal driver,
change usb port,
reboot pc..
Old 12-01-2011, 20:48   #39 (permalink)
Member: 530467
Smile
hola acavo de comprar la zx3 combo y estoy intentando desbloquear el samsung sgh-a687 de att, me queda claro como hacerlo usando el samsung tool3g v8.6 ya lo descarge y seleccionando el modelo a979 pero mi problema es que no me abre el programa me aparece la primer pagina del mismo pero no abre espero alguien me pueda ayudar con eso se los agradecere mucho bye
Old 12-08-2011, 08:25   #40 (permalink)
Member: 596251
Thanks Meter: 32
Z3x S5600 Unlocking
Searching USB Device... not found
Searching USB Device... detected (COM12)
Reading Phone Info... OK
Model: GT-S5600
Factory SW: S5600BVIH3
CountryCode: ORA
UniqueNumber: 80360000226677
MemoryPhone: K5R2G1GACC(S5600)S
SW: S5600BVIH3
IMEI: 35631503742892/9
Reading SysInfo... OK
Searching server... OK
Unlocking... OK
Old 12-08-2011, 08:26   #41 (permalink)
Member: 1702005
Thanks Meter: 3
nice share Thanksssssssssss
Old 12-17-2011, 15:13   #42 (permalink)
Denva's Avatar
Member: 1274304
Sonork: 100.1617965
Thanks Meter: 184
Detected:\\?\usb#vid_0bdb&pid_100e#5&ea588c7&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID900
Protocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:01:11)
Freeze code: 20209206
NET lock: #7465625*638*84759195#
Old 12-19-2011, 13:23   #43 (permalink)
descarado's Avatar
Member: 774392
Thanks Meter: 17
check that your box is properly installed
Old 01-02-2012, 09:26   #44 (permalink)
Registered User
Member: 865598
Sonork: 100.1609492
Thanks Meter: 461
Great Job Good Info .....................
Old 04-21-2012, 10:11   #45 (permalink)
G.G
Member: 1300517
Sonork: 100.1601031
Thanks Meter: 99
Arrow
with out battry do unlock work 100%
Detected:\\?\usb#vid_0bdb&pid_100e#5&2d753ade&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opening Port... OK
Flash ID900
Protocol:0401
Reading Data... OK
Calculating codes... OK (time - 00:00:28)
Freeze code: 03824686
NET lock: #7465625*638*58270592#
The Following User Says Thank You to G.G For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.17244 seconds with 8 queries
