11-14-2012, 19:01 | #2 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1214236 Status: Offline Sonork: stoledo043 Thanks Meter: 4 | Solved Thanks for all the help.... Here is solution, works 100%: z3x, select model E1200M, settings: flash mode, and direct unlock. Keep holding power button untill "sending loader 1... OK". You can close the thread. |
07-27-2013, 21:36 | #5 (permalink) |
Junior Member Join Date: Apr 2013 Location: Paraguay
Member: 1915610 Status: Offline Thanks Meter: 2 | E-1260L red blinking letters well finally i did it, with z3x you select model E-1200M, in com port you select your box serial port, u need samsung cable 3300 - you load in bin the file which i uploaded and very important you set speed to 115200 (lowest), one more thing in settings model tab FLASH MODE should be selected and no other thing, then select WRITE FIRMWARE and press power on connected phone until loader 2 starts going, wait for at least 20 min and job done |
The Following User Says Thank You to gate37 For This Useful Post: |
07-27-2013, 21:44 | #6 (permalink) |
Member: 1915610 Status: Offline Thanks Meter: 2 | here the link for the file to repair red blinking letters in E1260L GT-E1260L_slow.bin - Download - 4shared |
