02-26-2018, 18:26 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Egypt_Cairo Age: 41
Member: 111140 Status: Offline Thanks Meter: 75 | Unlock SAMSUNG SM-J710MN I tried unlock samsung SM-J710MN but i have these error UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J710MN Software version: 30.8 Waiting ADB device... OK Reading phone info... Model: SM-J710MN Android version: 7.0 Product code: SM-J710MZKUTTT Phone version: J710MNUBU4BRA1 PDA version: J710MNUBU4BRA1 CSC version: J710MNUUB4BRA1 CSC country code: TRINIDAD AND TOBAGO CSC sales code: TTT HW version: MP 0.400 Phone SN: RF8JB0HK5SW Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-01-01 RF cal date: 20171105 IMEI: 357933078820595 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1 19) Done with Samsung Tool PRO v.30.8 I did root via EFT BUT Regards. GsmOrient. |
