07-25-2017, 18:38 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Beware of people Age: 47
Member: 512551 Status: Offline Sonork: 100.1626194 Thanks Meter: 66 | unlock successfully j510fn by z3x crdeit Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-J510FN Software version: 28.9 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J510FN Android version: 6.0.1 Product code: SM-J510FZKNPHN Phone version: J510FjjoXU2APL2 PDA version: J510FNXXU2APL4 CSC version: J5vopPHN2,,gvvcxxAPL2 CSC country code: The Netherlands CSC sales code: PHN HW version: MP 0.300 Phone SN: RV8J41NF6FP Chip name: MSM8916 Modem board: MSM8916 Security patch: 2016-12-01 RF cal date: 2017.04.26 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM8 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 57947596 NET lock: 26052705 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.9 |
