Old 11-06-2012, 14:14   #1 (permalink)
Member: 323481
Thanks Meter: 24
Unlock Verizon Galaxy S3 i535 as World GSM Phone - simplified method
1.You need to root your phone if you want to have data conections if not skip this step.
How to root instructions you have here: [GUIDE] For beginners - Root Verizon Samsung Galaxy S3 SCH-i535/d2vzw - xda-developers
2.From Google Play store install the following apps if you do not have them: APN Manager Pro (81 Square), Phone Info ([email protected]), Titanium Backup Pro.
3 Turn off phone, pull out battery and put in micro SIM from your foreign country.
4. Use Phone Info app to change preferred network type "Global" or "Gsm only" (click on Device Information and scroll down to the first box to change). Some have reported that other choices were needed for their providers, so you may have to experiment.
5. Reboot phone. You should have the SIM card working for phone calls.
6. In Titanium Backup Pro, go to Backup/Restore, find and “long select” APN Manager Pro, and then select “Convert to system app”.
7. Open APN Manager Pro, select Insert APN, and input the data needed from your desired service provider.
8. Reboot phone. You should have the SIM card working for phone and data.
9. Remove notification "NON-VERIZON SIM" :
Using Titanium Backup, delete(uninstall) or freeze an app called Setup wizard 1.0 (its icon is a red check mark with a magic wand) and that should remove the notification
10. Enjoy.
The Following 4 Users Say Thank You to kosta25 For This Useful Post:
Old 12-11-2012, 16:00   #2 (permalink)
sweetboy's Avatar
Member: 146939
Sonork: 100.1609615
Thanks Meter: 219
i have a sprint gs3 so i am unable to join in on the fun but i'm wondering if anyone has tried using "test mode" to set to GSM and 850/1900 bands? Test mode is built into Touchwiz so... obviously this works in Touchwiz only. Press *#22745927 to enable hidden menus. then install Netmonitor from the Play Store. Open Netmonitor > hit the menu button > Hit "Field Test".
Once in Test Mode you can go to UMTS > DEBUG SCREEN > PHONE CONTROL > NETWORK CONTROL > BAND SELECTION to set GSM Band preference.
then starting at the very beginning over test mode again... CDMA > COMMON > NEXT PAGE > NEXT PAGE > PREF MODE SET to select GSM/WCDMA ONLY.
curious if someone could get ATT HSPA going using the above methods.. perhaps requiring even more test mode edits(poke around but be careful).
do this step and u will able to use any gsm network
The Following 5 Users Say Thank You to sweetboy For This Useful Post:
Old 12-26-2012, 23:54   #3 (permalink)
TICTAC_M's Avatar
Member: 331361
Thanks Meter: 151
please i can not find it Phone Info ([email protected]) is posible post apk
thanks.
Old 12-31-2012, 22:00   #4 (permalink)
ketoevans's Avatar
Member: 1769612
Sonork: 100.1626332
Thanks Meter: 23
worked like a charm thanks.
Old 01-11-2013, 13:16   #5 (permalink)
pawansingh's Avatar
Member: 306087
Thanks Meter: 24
worked like a butter
thanks.
Old 01-11-2013, 17:16   #6 (permalink)
Member: 153893
Thanks Meter: 231
need this solution urgently and av try any means to do this phone but no help
pls need email address for someone to help me through team viewer
thank u
Old 01-14-2013, 11:27   #7 (permalink)
pawansingh's Avatar
Member: 306087
Thanks Meter: 24
no need of team viewer just follow the steps of mr.sweetboy
Old 01-14-2013, 11:41   #8 (permalink)
gurinder's Avatar
Member: 167191
Thanks Meter: 348
this should be in samsung section bro. But good move as u posted here with steps. BTW i535 direct unlock/code read is out with other tool. waiting for z3x to release it.
gurinder
Old 01-15-2013, 15:51   #9 (permalink)
zeljko_c's Avatar
Member: 407770
Thanks Meter: 18
Its is only for verzion i535???
Old 01-16-2013, 01:01   #10 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 703
Yeah ... only for Verizon ...
Old 01-16-2013, 01:39   #11 (permalink)
fostersara8
Guest
Posts: n/a
Member:
Is your site service operational
Old 01-16-2013, 10:28   #12 (permalink)
zeljko_c's Avatar
Member: 407770
Thanks Meter: 18
I have US Celluar R530U Galaxy S3 and I tryed this but no luck....
Old 01-16-2013, 10:28   #13 (permalink)
zeljko_c's Avatar
Member: 407770
Thanks Meter: 18
I have US Celluar R530U Galaxy S3 and I tried this but no luck....
Old 01-20-2013, 02:35   #14 (permalink)
Member: 1871188
I did exactly as Mr sweetboy said... And yes, i actually did it, so thanks a lot... I just need a little bit of help, and i wish u all wisdow people help me out... Ting is, i just have EDGE signal.... What can i do to get 3G ??? Is there any solution using netmonitor ??
I hope u guys help... Ur all awesome...
Old 01-21-2013, 16:34   #15 (permalink)
THE GREAT ONE's Avatar
Member: 751235
Sonork: 100.1662008
Thanks Meter: 521
after unlock error when making a call... any solution?
Page generated in 0.37432 seconds with 8 queries
