01-22-2013, 13:47 | #17 (permalink) |
Freak Poster Join Date: Jan 2006 Location: philippines
Member: 216705 Status: Offline Thanks Meter: 48 | we have thesame problem after using unlock procedure,s3 verizon can make phonecall to other network , but texting and other function work ok, anybody have a solution for this. |
01-24-2013, 08:39 | #21 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Calicut Kerala India Age: 46
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | i have galaxy s3 verison but i dont have a sim to start it up.. while switching it shows registering and stnds still.. i can't select the option for usb debugging to start rooting any one can help? |
02-08-2013, 03:01 | #23 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Georgetown
Member: 455304 Status: Offline Thanks Meter: 417 | 9. Remove notification "NON-VERIZON SIM" : Using Titanium Backup, delete(uninstall) or freeze an app called Setup wizard 1.0 (its icon is a red check mark with a magic wand) and that should remove the notification to me this last step is the problem why you call make a call but recieve... first i follow all the step and i got to make and recieve call but when i restarted for first time couldnt have make no call.. so i reflash phone and root and follow all the step expect 9 and everything seem to be working even after i restart |
03-17-2013, 17:31 | #25 (permalink) |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | which solution u tried? i have tried this..but it gives me error (inset sim) i have a sprint gs3 so i am unable to join in on the fun but i'm wondering if anyone has tried using "test mode" to set to GSM and 850/1900 bands? Test mode is built into Touchwiz so... obviously this works in Touchwiz only. Press *#22745927 to enable hidden menus. then install Netmonitor from the Play Store. Open Netmonitor > hit the menu button > Hit "Field Test". Once in Test Mode you can go to UMTS > DEBUG SCREEN > PHONE CONTROL > NETWORK CONTROL > BAND SELECTION to set GSM Band preference. then starting at the very beginning over test mode again... CDMA > COMMON > NEXT PAGE > NEXT PAGE > PREF MODE SET to select GSM/WCDMA ONLY. curious if someone could get ATT HSPA going using the above methods.. perhaps requiring even more test mode edits(poke around but be careful). |
03-23-2013, 09:27 | #27 (permalink) |
Insane Poster Join Date: Mar 2006
Member: 238772 Status: Offline Thanks Meter: 8 | Press *#22745927 to enable hidden menus. then install Netmonitor from the Play Store. Open Netmonitor > hit the menu button > Hit "Field Test". Once in Test Mode you can go to UMTS > DEBUG SCREEN > PHONE CONTROL > NETWORK CONTROL > BAND SELECTION to set GSM Band preference. then starting at the very beginning over test mode again... CDMA > COMMON > NEXT PAGE > NEXT PAGE > PREF MODE SET to select GSM/WCDMA ONLY. unlock done by this solution Last edited by niflas; 03-23-2013 at 09:36. |
04-09-2013, 15:04 | #28 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | if u want to use this phone in india then there is different method this will not work in india... Give u error Network not Available |
04-09-2013, 15:10 | #29 (permalink) |
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | no need to root no need unlock bootloder simple method for more info u may contact me on yahoo [email protected] who have calling problem |
04-11-2013, 08:17 | #30 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 451834 Status: Offline Thanks Meter: 57 | i535 convert done special thanks to mr msmmobilecenter for wonderful guide now no problem for incoming out gong calls tnks again |
The Following User Says Thank You to tej_thakar For This Useful Post: |
