06-15-2014, 17:15 | #2 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan Age: 35
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | 1. Power off the phone 2. Press and hold " volume down " + " home" button, then press power on button 3. Then warning screen will appear just like this : Warning!!! A custom OS can cause a critical problems in phone and installed applications. If you want to download a custom OS, press the volume up key, Otherwise, press the volume down key to cancel. Volume up : Continue Volume down : Cancel ( restart phone ) 4. Press " volume up " button to enter download Br. Babar Abbasi |
06-15-2014, 17:17 | #3 (permalink) |
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | If this doesn't work it means that one your your hard key is not working properly then you need any smasung force download cable when you put the cable in the phone will automatically boot into download mode. Br. Babar Abbasi |
06-15-2014, 17:41 | #6 (permalink) |
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | Yes if you are unable to put phone into download mode using the key combination i have posted above then one of the hard keys are not working properly most probably the volume down key or home key. Btw if you are professional you should buy any force download cable its not very costly but very usefull. Stay blessed Br. Babar Abbasi |
The Following User Says Thank You to androidlabs For This Useful Post: |
