Unlock Server
Old 11-04-2010, 20:20   #1 (permalink)
martin5200's Avatar
Member: 1269289
Unlocking gs290
Im trying to unlock a gs290 but it stucks at reading EEPROM, I tried with and without battery but stills the same...
What can i do?'
Old 11-05-2010, 11:13   #2 (permalink)
abdgsm's Avatar
Member: 738945
check foce boot and do read codes
Loading module , please wait...
PMB8877 Module 1.21 started. SW: Ver 2.2.8.0
Connecting to GS290 in UART Mode (COM4 ,921600)
Please reconnect battery, press and hold power button...
Phone found! (MCU:PMB8877) prebooting...
Release power button. Booting...
Reading info...
Force boot mode on!
Finished in 16 seconds
Reading EEPROM
Sending SEC pack...
Analising EEPROM...
Phone IMEI:3535430453*****
For operation finishing,do next :
1. power phone ON with original SIM
2. type 2945#*XXX# ,where XXX are model digits to enter unlock menu
3. Enter one of this code(s):
NCK[0]: 2425536509901120 (LOCKED)
NCK[1]: 9931505490661824 (NS)
NCK[2]: 8266145447515068 (SP)
NCK[3]: 5784104128275862 (CP)
Finished in 4 seconds
The Following User Says Thank You to abdgsm For This Useful Post:
Old 11-05-2010, 19:11   #3 (permalink)
martin5200's Avatar
Member: 1269289
men now it stucks at this :
Welcome to LG Infineon SGOLD3 TOOL v2x by NoName®
Models count: 80
Current OS : Windows XP
Welcome to Sgold3 Module!!
Count supported models - 80
***Disconnected***
TIP: Please reconnect phone battery / power source.
Please connect phone , it must be powered off
Booting... \\.\USB1
BOOT Failed
***Disconnected***
Booting... \\.\USB1
Phone found! (MCU:SG3_USB) prebooting...
Flash ID: 00FF00
*Note in USB mode flash id can be incorrectly read*
Force boot mode on!
Finished in 0 seconds
Reading EEPROM
Sending SEC pack...
Error of reading block!
Finished in 1 minutes 31 seconds.
***Disconnected***
Booting... \\.\USB1
Flash ID: 00FF00
Force boot mode on!
Unlocking...
Sending SEC pack...
Reading .
Old 11-05-2010, 19:31   #4 (permalink)
danrachita's Avatar
Member: 428861
Sonork: 100.1619141
For unlock without problems you must use GW300 cable on RJ45.
BR.
The Following 2 Users Say Thank You to danrachita For This Useful Post:
Old 11-08-2010, 12:24   #5 (permalink)
eaglemobiles's Avatar
Member: 330951
Not Available Message
Hi,
I have got my code read from micro box using gw300 cable but when i try to enter code i get error "Not avilable" i tried
2945#*71001# or 2945#*290# and 2945#*71002#
Any help will be grateful
regards
Old 11-08-2010, 19:35   #6 (permalink)
Crazy Poster
Member: 598070
Models count: 80
***Disconnected***
Booting... \\.\USB1
BOOT Failed
***Disconnected***
Booting... \\.\USB1
Flash ID: 00FF00
Force boot mode on!
Reading EEPROM
Sending SEC pack...
***Disconnected***
Booting... \\.\USB1
Flash ID: 00FF00
Force boot mode on!
Unlocking...
Sending SEC pack...
Reading .
I have the same problem and I try with others methods but any results. I havent RJ45 cable, so I need a solution with MicroUSB cable.
Thanks
Old 06-20-2011, 14:23   #7 (permalink)
Member: 1353395
Sonork: 100.1607424
all time give mi this error
and wtih other time wtih other pohe is same error
Welcome to LG Multi Platform GOLD TOOL v3x by NoName®
Disconnected.
Count supported models - 128
Port list updated!
Port list updated!
PMB8877 Module 2.1 started. SW: Ver 3.6.0.0
Flash ID: 00FF00
BOOT Stage Finished , sending authority...
hi gaid helop mi
Old 06-22-2011, 17:08   #8 (permalink)
Member: 1509390
Use 102 cable
Use lg 102 cable in z3x .
1.phone off
2.press read info -connect cable -then u found nck code
welcome to lg multi platform gold tool v3x by noname®
current os : Windows xp
welcome to sgold3 module!!
Disconnected.
Tip: Please reconnect phone battery / power source.
port list updated!
Port list updated!
Pmb8877 module 2.1 started. Sw: Ver 3.6.0.0
please connect phone , it must be powered off
phone found! (mcu:sg3_usb) prebooting...
Flash id: 00ff00
*note in usb mode flash id can be incorrectly read*
boot stage finished , sending authority...
Hi gaid helop mi
Old 06-22-2011, 17:13   #9 (permalink)
Member: 1509390
Use 102 cable
1.phone off
Old 06-22-2011, 20:46   #10 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Disconnected.
Port list updated!
Port list updated!
Flash ID: 00FF00
hi gaid helop mi
Faced same problem with other mobile, just use older version of tool.
Old 06-23-2011, 07:17   #11 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
use cable gs102 and phone power on post result
Old 06-24-2011, 12:05   #12 (permalink)
Member: 1509390
use cable gs 102
if u have z3x use cable gs 102..
after press read info connect cable then u will find da nck cod
What can i do?'
Old 06-25-2011, 16:42   #13 (permalink)
Member: 1318873
you can use usb cable for read code after that you put a original sim or test card for moto or sony ericsson and you type 2945 dyaz etoile 290 dyaz an engeniring menu appear enter the nck code the phone restart put any sim enjoy after that
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:06
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 07-09-1999 22:08
Page generated in 0.43380 seconds with 11 queries
