06-19-2015, 13:58 | #1 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2227394 Status: Offline Thanks Meter: 1 | Update 21.5 and Flashing P605 Issue It just cannot flash it and shows this error Code: File analysis... OK Total file size: 0x90AC8F14 (2314 Mb) Searching USB Flash Interface... detected COM94 Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending sdi.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending modem.bin... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... error timeout Done with Samsung Tool PRO v.21.5 While same file flashed ok with ODIN Code: <ID:0/094> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> BL_P605XXUCNK1_CL3257320_QB2936883_REV00_user_low_ship_MULTI_CERT.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> AP_P605XXUCNK1_CL3257320_QB2936883_REV00_user_low_ship_MULTI_CERT.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CP_P605XXUCNG1_2111511_REV00_user_low_ship_MULTI_CERT.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CSC_VFG_P605VFGCNK1_CL3334902_QB3031599_REV00_user_low_ship_MULTI_CERT.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/094> Odin v.3 engine (ID:94).. <ID:0/094> File analysis.. <ID:0/094> SetupConnection.. <ID:0/094> Initialzation.. <ID:0/094> Set PIT file.. <ID:0/094> DO NOT TURN OFF TARGET!! <ID:0/094> Get PIT for mapping.. <ID:0/094> Firmware update start.. <ID:0/094> SingleDownload. <ID:0/094> aboot.mbn <ID:0/094> NAND Write Start!! <ID:0/094> sbl1.mbn <ID:0/094> rpm.mbn <ID:0/094> tz.mbn <ID:0/094> sdi.mbn <ID:0/094> NON-HLOS.bin <ID:0/094> boot.img <ID:0/094> recovery.img <ID:0/094> system.img.ext4 <ID:0/094> modem.bin <ID:0/094> Transmission Complete.. <ID:0/094> Now Writing.. Please wait about 2 minutes <ID:0/094> Receive Response from boot-loader <ID:0/094> cache.img.ext4 <ID:0/094> hidden.img.ext4 <ID:0/094> RQT_CLOSE !! <ID:0/094> RES OK !! <ID:0/094> Removed!! |
