Old 11-27-2017, 17:24   #1 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Sonork: TG: CodebUnlocks
Thanks Meter: 868
VS425pp y VS425lpp correct procedure for unlock! [TUTO]
100% TESTED by ME!
Before begin you must download this file FILES FOR UNLOCK VS425PP
1: Select model K120 and flash the TOT file with 7.6GB from file you previously download.
You gonna get and error (Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000118]].)
Don't disconnect phone and go to step #3
LG 2-3G Tool v9.43
supported models: 1543
Mode: Normal
Model: VS425PP8
Build version:  Dec  1 201515:39:01Nov 11 201522:00:00VS425PP8
SW Version: MPSS.JO.1.0.c5.7-00005-M8909EAAAANVZM-1.35346.3
IMEI: 00000000000000-0
BlueTooth Address: 00:00:00:00:00:00
Phone Code:
SPC: 000000
Elapsed: 2 secs. --> (v9.43)
Mode: Emergency
Model: K120
Read info...
Laf Protocol: 01000003
Model name: VS425PP
Software verion: VS425PP8
Android verion: 5.1.1
Target operator: VZW
Target country: US
IMEI: 000000000000000
Elapsed: 4 secs. --> (v9.43)
Phone mode is DOWNLOAD
Start flashing.
  Open TOT File : E:\Downloads\LG-VS425pp\LG-VS425pp\primero este\LGK120AT-00-V10b-CRK-US-JAN-26-2016-ARB00+0.tot
  Model : VS425PP
  SwVersion : VS425PP1
  BuildTime :
  Total Files : 42
Model name: VS425PP
Target country: US
Start direct download mode
Write "PrimaryGPT" partition #1 of 42
Write "modem" partition #2 of 42
Write "sbl1" partition #3 of 42
Write "tz" partition #4 of 42
Write "rpm" partition #5 of 42
Write "aboot" partition #6 of 42
Write "sbl1bak" partition #7 of 42
Write "tzbak" partition #8 of 42
Write "rpmbak" partition #9 of 42
Write "abootbak" partition #10 of 42
Write "modemst1" partition #11 of 42
Write "modemst2" partition #12 of 42
Write "ssd" partition #13 of 42
Write "DDR" partition #14 of 42
Write "fsg" partition #15 of 42
Write "fsc" partition #16 of 42
Write "sec" partition #17 of 42
Write "keystore" partition #18 of 42
Write "encrypt" partition #19 of 42
Write "eksst" partition #20 of 42
Write "devinfo" partition #21 of 42
Direct download error.
Flashing error.
Elapsed: 27 secs. --> (v9.43)
2: After flash the first file (7.6GB) don't disconnect phone and flash de second file (2.7GB)
Mode: Emergency
Model: K120
Read info...
Model name: VS425PP
Target country: US
Start flashing.
  Open TOT File : E:\Downloads\LG-VS425pp\LG-VS425pp\LGK120AT-00-V10b-CRK-US-JAN-26-2016-ARB00+0.tot
  Model : VS425PP
  BuildTime :
  Total Files : 19
Model name: VS425PP
Target country: US
Write "PrimaryGPT" partition #1 of 19
Write "modem" partition #2 of 19
Write "sbl1" partition #3 of 19
Write "tz" partition #4 of 19
Write "rpm" partition #5 of 19
Write "aboot" partition #6 of 19
Write "sbl1bak" partition #7 of 19
Write "tzbak" partition #8 of 19
Write "rpmbak" partition #9 of 19
Write "abootbak" partition #10 of 19
Write "sec" partition #11 of 19
Write "raw_resources" partition #12 of 19
Write "raw_resourcesbak" partition #13 of 19
Write "persist" partition #14 of 19
Write "laf" partition #15 of 19
Write "boot" partition #16 of 19
Write "recovery" partition #17 of 19
Write "factory" partition #18 of 19
Write "system" partition #19 of 19
Erase "rct" partition
Done.
Elapsed: 273 secs. --> (v9.43)
3: Repair imei using imei 0 fix function.
Repair IMEI...
Search LG Modem port...
LG Modem port not detected!
Port already opened!
Elapsed: 17 secs. --> (v9.43)
NOTE: After finish phone must be unlocked if not you can unlock as k120..
Hope this can help some one...
Regars
The Following 32 Users Say Thank You to Mr_F10ch3 For This Useful Post:
Old 11-29-2017, 16:24   #2 (permalink)
Member: 2703335
Thanks Meter: 22
All Done! but service Disabled! i try search for network, but error!
My sim is gsm not cdma!
Old 11-30-2017, 18:10   #3 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 868
Repair imei using imei 0 fix option...
Old 12-07-2017, 17:38   #4 (permalink)
Member: 2679051
Thanks Meter: 4
Can you explain a little? its supposed to be cdma phone, how does this work?
Old 12-07-2017, 18:05   #5 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 868
You all ready say "its supposed to be"
But is not, you can unlock it, if you follow my guide...
Just try....
The Following User Says Thank You to Mr_F10ch3 For This Useful Post:
Old 12-07-2017, 18:13   #6 (permalink)
Member: 2679051
Thanks Meter: 4
Just try....
Thanks, im downloading right now
I see k120 and vs425pp have same processor and very similar phone, have you tried this on other phones?
Old 12-07-2017, 18:17   #7 (permalink)
Member: 2679051
Thanks Meter: 4
I mean, how can I know when a phone "supposed to be" only cdma can actually work GSM flashing another firmware from similar phone?
Old 12-07-2017, 18:25   #8 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 868
Some proof attached !
Old 12-07-2017, 18:30   #9 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 868
Phone have GSM bands 850/1900 also without convert to k120 it work but only with LTE simcards and only work on sms and data, can't make calls.
NOTE: i can confirm vs425pp works on H+ and vs425lpp works on LTE
Old 12-07-2017, 18:39   #10 (permalink)
Member: 2679051
Thanks Meter: 4
Then it should work on any cdma phone that comes with sim reader?
Old 12-07-2017, 18:53   #11 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 868
Not all, for example LG-LS770 don't work on GSM and have sim reader.
Some phones bands/frequency involve a hardware part.
Old 12-07-2017, 23:21   #12 (permalink)
Member: 220874
Thanks Meter: 64
thanks it works
almost one year whit 3 phones
thank you
Old 12-30-2017, 18:22   #13 (permalink)
Pablo Velasqu's Avatar
Member: 2074524
Sonork: 100.1627435
Thanks Meter: 135
I managed to do the whole process with octupus
Welcome to Octoplus/Octopus Box LG Software version 2.7.7
Checking data...OK
Platform: LG Qualcomm
Selected port: COM286
Selected model: VS425LPP
Reading info...
Mode: Emergency
Initializing flash...OK
SW version: LGK121AT-00-V10b-TLS-CA-FEB-02-2016+0
Android version: 5.1.1
LAF Version: 1.2
Product ID: VP03S170911002543
IMEI: 358402-08-590114-4
Hardware: rev_10
Opening "LGK120AT-00-V10b-CRK-US-JAN-26-2016-ARB00+0.tot"...OK
Firmware version: VS425PP1
Firmware model: VS425PP
File declared for different phone model!
Performed by 2.7.7 Software version.
Checking data...OK
Selected model: VS425PP
Reading info...
Model ID: LG-K121
Battery level: 84%
SW Version: K12110b
Mode: Emergency
LAF Version: 1.2
Hardware: rev_10
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any
installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your
computer during the flashing!
Prepairing firmware...OK
Setting options...OK
Reading partitions...OK
Formating USERDATA...OK
Formating ENCRYPT...OK
Writing 1/42 PrimaryGPT...OK
Writing 2/42 modem...OK
Writing 3/42 sbl1...OK
Writing 4/42 tz...OK
Writing 5/42 rpm...OK
Writing 6/42 aboot...OK
Writing 7/42 sbl1bak...OK
Writing 8/42 tzbak...OK
Writing 9/42 rpmbak...OK
Writing 10/42 abootbak...OK
Writing 11/42 modemst1...OK
Writing 12/42 modemst2...OK
Writing 13/42 ssd...OK
Writing 14/42 DDR...OK
Writing 15/42 fsg...OK
Writing 16/42 fsc...OK
Writing 17/42 sec...OK
Writing 18/42 keystore...OK
Writing 19/42 encrypt...OK
Writing 20/42 eksst...OK
Writing 21/42 devinfo...Failed!
Checking data...OK
Reading info...
Model ID: LG-K121
Battery level: 84%
SW Version: K12110b
Mode: Emergency
LAF Version: 1.2
Hardware: rev_10
Writing 1/19 PrimaryGPT...OK
Writing 2/19 modem...OK
Writing 3/19 sbl1...OK
Writing 4/19 tz...OK
Writing 5/19 rpm...OK
Writing 6/19 aboot...OK
Writing 7/19 sbl1bak...OK
Writing 8/19 tzbak...OK
Writing 9/19 rpmbak...OK
Writing 10/19 abootbak...OK
Writing 11/19 sec...OK
Writing 12/19 raw_resources...OK
Writing 13/19 raw_resourcesbak...OK
Writing 14/19 persist...OK
Writing 15/19 laf...OK
Writing 16/19 boot...OK
Writing 17/19 recovery...OK
Writing 18/19 factory...OK
Writing 19/19 system...Failed!
Error code: ZXLCALSZXC
Checking data...OK
Reading info...
Model ID: LG-K121
Battery level: 85%
SW Version: K12110b
Mode: Emergency
LAF Version: 1.2
Hardware: rev_10
Writing 19/19 system...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Writing firmware done!
Old 01-04-2018, 15:19   #14 (permalink)
Member: 2394513
Thanks Meter: 8
i have a big issue
i flash the phone with the files posted here everything works ..except that the phone doesnt connect and imei is 0 dont know how to fix it any ideas
Old 01-04-2018, 15:24   #15 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 868
Enable port check test, you can saw how in software help, and change usb to mtp mode (this must be very quickly) then repair imei with imei 0 fix
The Following 3 Users Say Thank You to Mr_F10ch3 For This Useful Post:
Page generated in 0.29033 seconds with 9 queries
