Old 01-30-2018, 20:53   #16 (permalink)
Member: 2621350
Thanks Meter: 11
hi , i flashed 2 files and after rapaired imei. but network not work. Imei is correct but no wireles ((
Don't see any operators and write network search error
Old 01-30-2018, 21:30   #17 (permalink)
Member: 2621350
Thanks Meter: 11
or imei must be restored only by octopus?
Old 02-01-2018, 21:37   #18 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Try select D820 and make IMEI 0 Fix.
Post result here.
Old 03-01-2018, 22:58   #19 (permalink)
Member: 2228428
Thanks Meter: 51
Originally Posted by Mr_F10ch3 View Post
100% TESTED by ME!
Before begin you must download this file FILES FOR UNLOCK VS425PP
1: Select model K120 and flash the TOT file with 7.6GB from file you previously download.
You gonna get and error (Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000118]].)
Don't disconnect phone and go to step #3
LG 2-3G Tool v9.43
supported models: 1543
Mode: Normal
Model: VS425PP8
Build version:  Dec  1 201515:39:01Nov 11 201522:00:00VS425PP8
SW Version: MPSS.JO.1.0.c5.7-00005-M8909EAAAANVZM-1.35346.3
IMEI: 00000000000000-0
BlueTooth Address: 00:00:00:00:00:00
Phone Code:
SPC: 000000
Elapsed: 2 secs. --> (v9.43)
Mode: Emergency
Model: K120
Read info...
Laf Protocol: 01000003
Model name: VS425PP
Software verion: VS425PP8
Android verion: 5.1.1
Target operator: VZW
Target country: US
IMEI: 000000000000000
Elapsed: 4 secs. --> (v9.43)
Phone mode is DOWNLOAD
Start flashing.
  Open TOT File : E:\Downloads\LG-VS425pp\LG-VS425pp\primero este\LGK120AT-00-V10b-CRK-US-JAN-26-2016-ARB00+0.tot
  Model : VS425PP
  SwVersion : VS425PP1
  BuildTime :
  Total Files : 42
Model name: VS425PP
Target country: US
Start direct download mode
Write "PrimaryGPT" partition #1 of 42
Write "modem" partition #2 of 42
Write "sbl1" partition #3 of 42
Write "tz" partition #4 of 42
Write "rpm" partition #5 of 42
Write "aboot" partition #6 of 42
Write "sbl1bak" partition #7 of 42
Write "tzbak" partition #8 of 42
Write "rpmbak" partition #9 of 42
Write "abootbak" partition #10 of 42
Write "modemst1" partition #11 of 42
Write "modemst2" partition #12 of 42
Write "ssd" partition #13 of 42
Write "DDR" partition #14 of 42
Write "fsg" partition #15 of 42
Write "fsc" partition #16 of 42
Write "sec" partition #17 of 42
Write "keystore" partition #18 of 42
Write "encrypt" partition #19 of 42
Write "eksst" partition #20 of 42
Write "devinfo" partition #21 of 42
Direct download error.
Flashing error.
Elapsed: 27 secs. --> (v9.43)
2: After flash the first file (7.6GB) don't disconnect phone and flash de second file (2.7GB)
Mode: Emergency
Model: K120
Read info...
Model name: VS425PP
Target country: US
Start flashing.
  Open TOT File : E:\Downloads\LG-VS425pp\LG-VS425pp\LGK120AT-00-V10b-CRK-US-JAN-26-2016-ARB00+0.tot
  Model : VS425PP
  BuildTime :
  Total Files : 19
Model name: VS425PP
Target country: US
Write "PrimaryGPT" partition #1 of 19
Write "modem" partition #2 of 19
Write "sbl1" partition #3 of 19
Write "tz" partition #4 of 19
Write "rpm" partition #5 of 19
Write "aboot" partition #6 of 19
Write "sbl1bak" partition #7 of 19
Write "tzbak" partition #8 of 19
Write "rpmbak" partition #9 of 19
Write "abootbak" partition #10 of 19
Write "sec" partition #11 of 19
Write "raw_resources" partition #12 of 19
Write "raw_resourcesbak" partition #13 of 19
Write "persist" partition #14 of 19
Write "laf" partition #15 of 19
Write "boot" partition #16 of 19
Write "recovery" partition #17 of 19
Write "factory" partition #18 of 19
Write "system" partition #19 of 19
Erase "rct" partition
Done.
Elapsed: 273 secs. --> (v9.43)
3: Repair imei using imei 0 fix function.
Repair IMEI...
Search LG Modem port...
LG Modem port not detected!
Port already opened!
Elapsed: 17 secs. --> (v9.43)
NOTE: After finish phone must be unlocked if not you can unlock as k120..
Hope this can help some one...
Regars
Made the process on a VS425PP
no gsm option even tho phone has signal and can make calls,
but usb connection doesnt work properly anymore, it doesnt let me set as MTP, it says software installer error something like that, any way around this?
thanks
Old 03-02-2018, 13:23   #20 (permalink)
Member: 482218
Thanks Meter: 119
phone only works wcdma and lte in this state, no GSM. to make mtp work again i think you just need to do wipe.
Old 03-02-2018, 15:29   #21 (permalink)
Member: 914220
Thanks Meter: 206
Post result here.
i fix imei wirh k120 and work fine
Old 03-06-2018, 16:03   #22 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Sonork: TG: CodebUnlocks
Thanks Meter: 868
thanks
You must tap cancel at error warning and very quickly select mpt, very very quickly.
Old 03-09-2018, 15:54   #23 (permalink)
Member: 283480
Hello, Can I do this procedure selecting the model LS675 in Z3x v9.5?
I made a full backup of this phone vs425pp selecting the Ls675 model and was restored successfully.
Thanks in advance
Old 03-14-2018, 15:24   #24 (permalink)
Member: 2569104
Thanks Meter: 42
Gsm 900 mhz ???
did the whole process but no signal, im in cuba frequency here is 900mhz, i think this phone doesn't have 900, please someone to confirm my theory, thanks in advance
Old 03-15-2018, 23:44   #25 (permalink)
Member: 2247675
Thanks Meter: 141
not work 900mhz gsm band !!!
Phone have GSM bands 850/1900 only
Old 03-18-2018, 18:50   #26 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 868
I think for cuba you only need do the unlock with any tool that support this model, without flash
Old 03-22-2018, 04:12   #27 (permalink)
Member: 2144094
Thanks Meter: 2
LG 2-3G Tool v9.48
modelos soportados: 1555
Teléfono no detectado!, por favor seleccione manualmente el puerto o reinicie su PC!
Modo: Emergencia
modelo K120
Read info...
Model name: VS425PP
Target country: US
Chipset: msm8909
IMEI: 354874075244053
Transcurrido 5 segundos --> (v9.48)
Modo: Emergencia
modelo K120
Read info...
Model name: VS425PP
Target country: US
Chipset: msm8909
Transcurrido 4 segundos --> (v9.48)
Telefono en modo DESCARGA
Comenzando a Parpadear
Open TOT File : C:\Ugly Phones\LG-VS425pp\primero este\LGK120AT-00-V10b-CRK-US-JAN-26-2016-ARB00+0.tot
Modelo: VS425PP
Versión de Software: VS425PP1
Tiempo de construcción:
Total Files : 42
Model name: VS425PP
Target country: US
Chipset: msm8909
Error de parpadeo
Transcurrido 36 segundos --> (v9.48)
Modo: Emergencia
modelo K120
Read info...
Model name: VS425PP
Target country: US
Chipset: msm8909
Open TOT File : C:\Ugly Phones\LG-VS425pp\LGK120AT-00-V10b-CRK-US-JAN-26-2016-ARB00+0.tot
Modelo: VS425PP
Total Files : 19
Model name: VS425PP
Target country: US
Chipset: msm8909
Hecho.
Transcurrido 201 segundos --> (v9.48)
Old 03-22-2018, 04:15   #28 (permalink)
Member: 2144094
Thanks Meter: 2
Originally Posted by prre View Post
LG 2-3G Tool v9.48
Modo: Emergencia
modelo K120
Read info...
Model name: VS425PP
Target country: US
Chipset: msm8909
Modo: Emergencia
modelo K120
Read info...
Model name: VS425PP
Target country: US
Chipset: msm8909
IMEI: xxxxxxxxxxxxxxx
Modelo: VS425PP
Total Files : 42
Model name: VS425PP
Target country: US
Chipset: msm8909
Error de parpadeo
Modo: Emergencia
modelo K120
Read info...
Model name: VS425PP
Target country: US
Chipset: msm8909
Modelo: VS425PP
Total Files : 19
Model name: VS425PP
Target country: US
Chipset: msm8909
Hecho.
"With IMEI 0, to repair try to use EFS Professional -> Qualcomm NV Tools"
Old 04-09-2018, 06:50   #29 (permalink)
Member: 2527159
Thanks Meter: 35
help with this
100% TESTED by ME!
LG 2-3G Tool v9.43
Mode: Normal
Model: VS425PP8
Phone Code:
SPC: 000000
Mode: Emergency
Model: K120
Read info...
Model name: VS425PP
Target country: US
Start flashing.
  Model : VS425PP
  BuildTime :
  Total Files : 42
Model name: VS425PP
Target country: US
Flashing error.
Mode: Emergency
Model: K120
Read info...
Model name: VS425PP
Target country: US
Start flashing.
  Model : VS425PP
  BuildTime :
  Total Files : 19
Model name: VS425PP
Target country: US
Done.
Repair IMEI...
Regars
hello, did you have ticked the "flash in direct mode" in options???
asking because i get "invalid partition table" when i try to flash and nothing happens
Old 04-09-2018, 16:59   #30 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 868
no, im not ticked flash in direct mode...
The Following User Says Thank You to Mr_F10ch3 For This Useful Post:
Page generated in 0.33520 seconds with 9 queries
