07-26-2018, 23:23 | #46 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: . Age: 35
Member: 400280 Status: Offline Thanks Meter: 83 | Quote:
Phone bootloader repaired with vs425lpp files and Done.. now I try this tuto but with the second firmware always I get error in file #19 System (50% 85% 13%) how can I complete the flash? (octo same problem). | |
09-19-2018, 06:33 | #47 (permalink) | |
Freak Poster Join Date: Mar 2006 Age: 44
Member: 252859 Status: Offline Thanks Meter: 53 | Quote:
Install LG bridge to solve this problem | |
10-15-2018, 20:04 | #48 (permalink) |
Crazy Poster Join Date: Sep 2007
Member: 587029 Status: Offline Thanks Meter: 8 | i tried your solution successfully but no network still. My region only have these frequencies for gsm 900mhz,1800mhz. LTE bands b3,b7,b20,b28 & b40. could this be the reasons for no network? |
12-11-2018, 12:47 | #51 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | i have done this all succes, flash, unlock, imei repair. the problem is it is only cdma / LTE so signal is hard to find specially on locations that does not have LTE. also, you need to be fast in selecting mtp so you can detect it after cancel |
12-11-2018, 15:35 | #52 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | For 900/1800 no need flash, phone comes unlocked for that or can do unlock with octo, for 850/1900 need do step by step in this post |
12-27-2018, 22:58 | #53 (permalink) | |
Freak Poster Join Date: Dec 2005
Member: 214169 Status: Offline Thanks Meter: 37 | Quote:
after that open quick shortcut maker and search for phone then click on try then you get option to change from installer to select mtp. i did it. this is my solution. created by me jimmyd4eva | |
The Following User Says Thank You to jimmy-d For This Useful Post: |
12-27-2018, 23:00 | #54 (permalink) |
Member: 214169 Status: Offline Thanks Meter: 37 | wiping phone wont help you. just fallow this procedure that i created please install the google account manager version for that phone, then install quick shortcut maker after that open quick shortcut maker and search for phone then click on try then you get option to change from installer to select mtp. i did it. this is my solution. created by me jimmyd4eva |
03-14-2019, 21:04 | #57 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | I tried the same operations, but can't get any network coverage... 900\1800 GSM, 2100 3G and 2600 LTE. Guys, can you tell me what type and network freq. are you using on this phone? CDMA doesn't work also |
