Old 12-04-2009, 12:01   #1 (permalink)
Cheater -Don't Deal with him-
Member: 390492
Thanks Meter: 67
z3x team need help pls
Selected model: C5212_s
Selected com port: COM9
Selected speed port: 921600
Please, connect phone and press shortly power button
Phone Detected
Sending loader1... OK
ARM version 3B11
Sending loader2... OK
Flash ID: 00EC2206000100000034
Slave Detected
Sending slave loader1... OK
ARM version slave 3541
Sending slave loader2... OK
Flash ID: 00EC240200010000E1D0
NAND format - ок
Start NOR flash
NOR flash - ok
Start Flash TFS
Mount NAND - ok
Create DIR - ok
TFS - Fail
Send TFS - fail
Elapsed time: 737 second, sw ver: 3.4.0014
Selected model: C5212_m
Phone Detected
ARM version 3B11
NAND format - ок
Start NOR flash
NOR flash - ok
Start Flash TFS
Mount TFS - ok
Create DIR - ok
Download - ok
Elapsed time: 1443 second, sw ver: 3.4.0014
Phone Detected
ARM version 3B11
Write EEP - ok
Elapsed time: 42 second, sw ver: 3.4.0014
Please, connect phone and press power button 3 seconds
Phone Detected
Use automatic parameters
Phone in TAT MODE
Phone IMEI: 35283203015969
Phone SW: C5212XAIC7
Phone BT ADDR: 0021-D1-6554F5
Phone SN: RPNS327449
Deactivated MSL - TRUE
Write imei - ok
Repair - ok
Elapsed time: 11 second, sw ver: 3.4.0014
flash done all OK phone starts up without simcard all ok
but when insert simcart phone hangs on start logo
whats the sollution for this ?
best regards
Old 12-04-2009, 13:37   #2 (permalink)
freedomqn's Avatar
Member: 347720
Sonork: xxx
Thanks Meter: 204
what past problem with phone?insert one sim still hang on?this problem come to hardware
Old 12-04-2009, 13:58   #3 (permalink)
Member: 390492
Thanks Meter: 67
bro phone was 100% working phone i had to flash for my *******r to an spanish language after flash and all phone not start with simcard hangs on logo
without simcard phone does start thats realy weird if there was an hardware problem than phone shouldnt even start without simcard also.
best regards
Old 12-04-2009, 14:36   #4 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
Phone Detected
ARM version 3B11
Slave Detected
NAND format - ок
Start NOR flash
NOR flash - ok
Start Flash TFS
Mount NAND - ok
Create DIR - ok
TFS - Fail
Send TFS - fail
Problem in slave tfs flashing. check options format tfs.
Old 12-04-2009, 15:10   #5 (permalink)
Member: 390492
Thanks Meter: 67
mr blanq there are to versions of C5212 samsung in the list you have the c5212_s and c5212_m version and the phone is just C5212 which of this models do i need to choice .
best regards
Old 12-04-2009, 15:18   #6 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
i alread told in same tread. please next time use search button,
phone have 2 part: 2 dir phone inside: master and slave.
need flash each part main + tfs.
first flash master , second flash slave.
flash file is different for each part. 4 dif files.
Old 12-04-2009, 16:48   #7 (permalink)
Member: 390492
Thanks Meter: 67
thank you mr blanq will try that
best regards
Old 12-05-2009, 13:40   #8 (permalink)
Member: 390492
Thanks Meter: 67
thank you mr blanq phone is working 100 % now
the s and the m i tough they where other versions thats why didnt work
best regards
z3x team need help aljolas QUALCOMM Models (3G) 6 11-25-2009 08:21
cyclone team need help pls Gago_ Cyclonebox 1 10-31-2009 23:58
Pls help Z3x Team Mr.Blang pls help E250 prob mali_comm Z3X-Team Products 1 10-21-2009 18:31
FG team need help pls. Gago_ FuriousGold 3 10-13-2009 14:43
Page generated in 0.18876 seconds with 10 queries
