01-10-2016, 09:03 | #7 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | BACKUP INSTRUCTIONS: QCN UART cable: 1. Phone must be powered on. 2. Connect the phone to UART cable. 3. Choose correct COM port in port settings. 4. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. QCN USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose phone USB. 3. Type *#197328640#, select: Common - Diag Config - USB diag. 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select diagnostic port in port settings. 7. Press 'Read QCN' button to read backup or 'Write QCN' to restore. EFS Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. Operation: Read EFS Selected model: GT-I8552 Selected port: Software version: 23.9 ADB device not selected Done with Samsung Tool PRO v.23.9 |
01-10-2016, 09:04 | #8 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: GT-I8552 Selected port: COM18 SAMSUNG Mobile USB Serial Port Software version: 23.9 Reading phone info... OK Model: GT-I8552 Country code: ªU Cal date: ªU Factory SW: I8552XXANF2 Unique number: CK708CA96681460 Memory phone: ªU Phone S/N: 0000000000 PDA/CSC version: I8552XXANF2/I8552OJVANF1 Phone version: SW VERSION :None Phone HW: None Cal date: none Reading IMEI... OK IMEI: 447967894000448 Bypass MSL... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.23.9 |
01-10-2016, 09:05 | #9 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' if needed. Operation: Patch Certificate Selected model: GT-I8552 Selected port: COM18 SAMSUNG Mobile USB Serial Port Software version: 23.9 Reading phone info... Phone S/N: 0000000000 Reading IMEI... OK IMEI: 447967894000448 Patching CERT check... OK Reseting... OK Patching CERT check... done Done with Samsung Tool PRO v.23.9 |
01-10-2016, 09:08 | #13 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' if needed. Operation: Repair Selected model: GT-I8552 Selected port: COM18 SAMSUNG Mobile USB Serial Port Software version: 23.9 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' ADB device not selected Done with Samsung Tool PRO v.23.9 |
01-10-2016, 09:14 | #14 (permalink) |
01-10-2016, 09:14 | #15 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' if needed. Operation: Reset EFS Selected model: GT-I8552 Selected port: COM18 SAMSUNG Mobile USB Serial Port Software version: 23.9 ADB device not selected Done with Samsung Tool PRO v.23.9 |
