Old 11-24-2009, 05:11   #1 (permalink)
net monitor's Avatar
Member: 600970
Thanks Meter: 89
cu400 unlock done but... now emergency download
cu400 unloking done after 1 day emergency download..try to flash but efs write error..pls help z3x team...
Old 11-24-2009, 10:11   #2 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Try flash again
andrew_tm 2009
Old 11-24-2009, 11:03   #3 (permalink)
Member: 600970
Thanks Meter: 89
Originally Posted by andrew_tm View Post
Try flash again
andrew_tm 2009
i flash more 30 times same error and same problem....
so pls give me same informative tips....
Old 11-24-2009, 11:13   #4 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
How cable you use? 2in1?
andrew_tm 2009
Old 11-24-2009, 11:45   #5 (permalink)
Member: 600970
Thanks Meter: 89
lgu8110f 2in1 cable rj45 and usb... i use to flash usb cable in lgu8110f
Old 11-24-2009, 13:43   #6 (permalink)
freedomqn's Avatar
Member: 347720
Sonork: xxx
Thanks Meter: 204
and fix kp110 software show cable 7050 but it cable ke500 and must press power button about 8s for boot,thx
Old 11-25-2009, 05:46   #7 (permalink)
Member: 600970
Thanks Meter: 89
what do you mean?
Old 11-25-2009, 06:11   #8 (permalink)
Member: 600970
Thanks Meter: 89
mr andrew_tm and z3x team pls upload more flash file on support in cu400 flash file...
Old 11-25-2009, 11:12   #9 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
If you sure about phone try other flasher.
But phone can have hardware problem.
Hardware problem you can't solve with flashing.
Old 11-25-2009, 11:37   #10 (permalink)
Member: 600970
Thanks Meter: 89
i know hardware problem cant solve via flashing....but the phone is ok after unlock emergency download
Old 12-04-2009, 16:02   #11 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Contact to my in icq: 326 970 341 and we check this problem
andrew_tm 2009
CU400 Unlock Done!! unlock trigger ULT PRO 1 10-13-2009 14:22
s3500 said unlock done but not done irfan333 NSPRO 2 04-20-2009 18:17
china n73 i change PA but now Emergency on screen shani72 Chinese Models & Cloned Phones 1 01-29-2009 21:00
Cu400 unlocked done nadirghazi FuriousGold 0 01-07-2009 10:34
C975 smartclip unlock done But set can't Unlock aukonline Smart-Clip 14 03-28-2006 12:02
Page generated in 0.25568 seconds with 10 queries
